sittinhawk's avatar
sittinhawk
3 months ago
DK-DEV-AGI027-RA QSPI Verification Fails
I'm using the DK-DEV-AGI027-RA, and I have successfully programming the QSPI flash once and this was successfully and I am able to auto-boot on powerup.
However, now when I try to program a new load, I get "Operation Failed" at 2% during the "Performing on-chip verification on device 2." This is using the Programmer interface in Quartus.
This is the full order: "Erasing device 2" (completes), "Programming device 2" (completes), "Performing on-chip verification on device 2" (fails)
Am I required to have the board jumpers set to JTAG mode for programming QSPI? Or are there any other suggestions to allow successful programming/verifying?
  • JohnT_Altera's avatar
    JohnT_Altera
    I would recommend to set the the MSEL to JTAG mode before you performing the programming/verifying.
    • sittinhawk's avatar
      sittinhawk
      I tried using JTAG mode, but I'm still getting verify failed on the QSPI flash. Are there any official instructions for building and programming QSPI for this specific board?
        JohnT_Altera
        May I know if the programming work after power cycle if the verify is not being performed? May I know what is the TCK freq used?
