monkstein88's avatar
monkstein88
6 months ago
A topic explaining a problem with Cyclone V SoC - u-booting .rbf file failure - got rejected.
Hi Altera Comunity et al,
I guess this is more of a question for the support and moderator people of this forum. The situation is I just posted a topic explaining a problem I am experiencing with Cyclone V SoC—U-boot failing to load the .rbf (FPGA load configuration ) file , during initial system bootup. I put a lot of information - attached files, links, etc. to give better context around the issue. But that post got flagged as Spam and got rejected. And I am just wondering what to do here. I tried editing that post (removing links and removing attached files) several times already, but it still stays flagged as spam. I don't know what to do further to fix this :(
The original issue topic was : "Cyclone-V-SoC: U-Boot fails to fpga load .rbf file - Command 'load' failed: Error -6"
Anyone, please advise.
Thank you and Best Regards,
- Monk M.
  • monkstein88's avatar
    monkstein88
    6 months ago
    Hello Yoshiaki,
    Thank you so much for taking the effort to test the .rbf files I built and shared  on your own DE10-Nano system, and confirming them that they actually work. :)
    On my side, on my own QMTECH board, I did the check (performed the register read from U-Boot shell) of  the 'stat' register of the FPGA Manager Module, and I think I found my answer/reason for my troubles. So I had set MSEL SW to '01010' (ON-OFF-ON-OFF-ON) on my board, stopped at U-Boot, issued the command and got the below:
    => md ff706000 1
    ff706000: 00000058                             X...
      So, I do NOT get the expected: 'ff706000: 00000050 P...'  , but actually 'ff706000: 00000058 X...' . And then I checked my board physically , toggling one pin at a time , and then reading back the 'stat'  register after each pin change.  And it was found out that one of the pad pins (the PIN.5) of the DIP SW was broken. And toggling the one switch adjacent to that pin, made no change in the 'stat' register readout.
    So, I think the cause had been found for why Uboot can't load compressed .rbf succesfully - my board has a broken MSEL DIP SW pin and it just physically cannot apply/provide the MSEL = '01010'.  So, I have to fix my board in this case.
    Anyway, at this point, I think the issue is to be considered SOLVED. You can close this ticket.
    Much gratitutes Yoshiaki, you've been of great help!
    - Monk M.
  • YoshiakiS_Altera's avatar
    YoshiakiS_Altera
    Hello monkstein88,
    The issue was happened on the following code.
    https://github.com/altera-fpga/u-boot-socfpga/blob/socfpga_v2026.01/drivers/fpga/socfpga_gen5.c#L158
    static int fpgamgr_program_poll_initphase(void)
        unsigned long i;
        /* Additional clocks for the CB to enter initialization phase */
        if (fpgamgr_dclkcnt_set(0x4))
            return -5;
        /* (4) wait until FPGA enter init phase or user mode */
        for (i = 0; i < FPGA_TIMEOUT_CNT; i++) {
            if (fpgamgr_get_mode() == FPGAMGRREGS_MODE_INITPHASE)
                break;
            if (fpgamgr_get_mode() == FPGAMGRREGS_MODE_USERMODE)
                break;
        /* If not in configuration state, return error */
        if (i == FPGA_TIMEOUT_CNT)
            return -6;
        return 0;
    This issue most likely is happened on the mismatch of MSEL and generated RBF, or Device OPN mismatch.
    1) Check SOF. Please configure your SOF by Quartus Programmer via JTAG.
    If it fails, Device OPN is incorrect. Please update DEVICE section in your qmtech_c5soc_kfb_dual_sdram_ghrd.qsf.
    2) Check the compression mode of the RBF. Here are details of the settings.
    MSEL
    Configuration Scheme
    Compression
    00000
    FPPx16
    Disabled
    01010
    FPPx32
    Enabled
    3) Check your power supply. Does the output current of your power supply meet requirement of the board?
     Yoshiaki Saito
    YoshiakiS_Altera
    Hello monkstein88,
    Thank you for the update.
    I'm glad to hear .rbf without compression works fine.
    Could you please try the following combination?
    Mode
    MSEL
    Compression
    POR Delay
    FPPx16
    00010
    Enabled
    Fast
    FPPx32
    01010
    Enabled
    Fast
    FPPx16
    00110
    Enabled
    Standard
    FPPx32
    01110
    Enabled
    Standard
    Table 27.  Configuration Schemes for FPGA Configuration by the HPS
    https://docs.altera.com/r/docs/683126/21.2/cyclone-v-hard-processor-system-technical-reference-manual/fpga-configuration?tocId=oT8kgUpEZokq8aJ3ItYu8g
     Yoshiaki Saito
      monkstein88
      Hi, here's an update:
      I've tried again to generate compressed bitstream files (.rbf) and then feed it - to be loaded by UBoot, during boot-up. At the beginning, I took the uncrompressed .sof file created when building the Quartus HW project, and then used the 'Convert Programming Files...'  tool , to convert and compress the .sof file into .rbf file, using the following settings:
      And then used the created .rbf file to create a bootable and SD Card .img file. And then set the MSEL [4:0] switches = '00010' and  '00110' , according to the table:
      And then I tried all kinds of combinations , including the ones you posted:
      Mode
      MSEL
      Compression
      POR Delay
      FPPx16
      00010
      Enabled
      Fast
      FPPx32
      01010
      Enabled
      Fast
      FPPx16
      00110
      Enabled
      Standard
      FPPx32
      01110
      Enabled
      Standar
      And still , when booting the image, I get the '  Command 'load' failed: Error -6'  error , when Uboot is loading the .rbf file.   :(
      What I am supposed to do here, to get compressed FPGA configs to be booted? I am lost.... (I've attached a .zip file, containng my .sof, .rbf and .cof files used).
      Note: The board that I am using is a (QMTECH Cyclone V SoC board) clone of Terasic's DE10-Nano, so the provided (attached here) .rbf file is to be compatible with the Terasic's board. The .rbf file contains the hw design of the DE10-Nano GHRD project, from the provided Demo Projects by Terasic.  So nothing special.
        YoshiakiS_Altera
        Hello monkstein88,
        Thank you for testing .rbf again.
        We have verified .rbf with/without compress mode on Cyclone V SoC DevKit.
        Please double check of MSEL setting.
        Accdoring to QMTECH_Cyclone_V_SoC_KFB_Dual_SDRAM_Schematic_20240607_V01.pdf,
        Please keep in mind to set SW5 for MSEL to ON to represent 0 and to OFF to represent 1.
        Next , here are commands to generate .rbf from .sof.
        quartus_cpf -c -o bitstream_compression=on  soc_system.sof soc_system_comp_on.rbf
        quartus_cpf -c -o bitstream_compression=off soc_system.sof soc_system_comp_off.rbf
        Here are actual logs on Cyclone V SoC Dev Kit.
        In case of  MSEL = 01000 (FPPx32, Compress Off, Fast)
        U-Boot SPL 2025.07-g35abb4f1cedc-dirty (May 18 2026 - 13:18:14 +0900)
        DDRCAL: Scrubbing ECC RAM (1024 MiB).
        DDRCAL: SDRAM-ECC initialized success with 578 ms
        Trying to boot from MMC1
        U-Boot 2025.07-g35abb4f1cedc-dirty (May 18 2026 - 13:18:14 +0900)
        CPU:   Altera SoCFPGA Platform
        FPGA:  Altera Cyclone V, SE/A6 or SX/C6 or ST/D6, version 0x0
        BOOT:  SD/MMC Internal Transceiver (3.0V)
        DRAM:  1 GiB
        Core:  33 devices, 18 uclasses, devicetree: separate
        MMC:   dwmmc0@ff704000: 0
        Loading Environment from MMC... Reading from MMC(0)... *** Warning - bad CRC, using default environment
        In:    serial
        Out:   serial
        Err:   serial
        Model: Altera SOCFPGA Cyclone V SoC Development Kit
        Net:
        Warning: ethernet@ff702000 (eth0) using random MAC address - 4e:4c:9a:70:2d:81
        eth0: ethernet@ff702000
        Hit any key to stop autoboot:  0
        => load mmc 0:1 ${loadaddr} soc_system_comp_on.rbf
        2356140 bytes read in 120 ms (18.7 MiB/s)
        => fpga load 0 ${fileaddr} $filesize
        => load mmc 0:1 ${loadaddr} soc_system_comp_off.rbf
        7007204 bytes read in 351 ms (19 MiB/s)
        In case of MSEL = 01010 (FPPx32, Compress ON, Fast)
        DDRCAL: SDRAM-ECC initialized success with 579 ms
        DRAM:  1 GiB
        In:    serial
        Out:   serial
        Err:   serial
        Net:
        Warning: ethernet@ff702000 (eth0) using random MAC address - 1e:b9:e6:16:1a:1c
        Lastly, please upload your .sof file.
         Yoshiaki Saito
    monkstein88
    Ok, I will try to lay out the original problem I have been encountering.
    Currently I am experiencing a persistent issue with a QMTech Cyclone V SoC board (a very close clone of the Terasic DE10-Nano Board), trying to load the fpga configuration (.rbf) while the board is booting (U-Boot). While the .rbf is being loaded, I get an error: 'Command 'load' failed: Error -6' .
    Overall, the whole booting process works, my system is able to  go through the whole process: UBoot SPL -> UBoot -> Linux (logjn prompt). But a phase in between - which is the FPGA configuration loading is failing.
    Here's the U-Boot shell excerpt, where I prompt the system for a couple of things and then try to fpga load the .rbf file:
    => fpga info
    Altera Device
    Descriptor @ 0x3ffec7a0
    Family:         SoC FPGA
    Interface type: Fast Passive Parallel (FPP)
    Device Size:    4294967295 bytes
    Cookie:         0x0 (0)
    No Device Function Table.
    => printenv
    arch=arm
    baudrate=115200
    board=c5soc-kfb-dual-sdram
    board_name=c5soc-kfb-dual-sdram
    boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
    boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootarm.efi; if fdt addr -q ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
    boot_efi_bootmgr=if fdt addr -q ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr;fi
    boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf}
    boot_net_usb_start=usb start
    boot_prefixes=/ /boot/
    boot_script_dhcp=boot.scr.uimg
    boot_scripts=boot.scr.uimg boot.scr
    boot_syslinux_conf=extlinux/extlinux.conf
    boot_targets=mmc0 qspi pxe dhcp
    bootcmd=load mmc 0:1 ${loadaddr} soc_system.rbf && fpga load 0 ${loadaddr} $filesize; sysboot mmc 0:1 any ${scriptaddr} /extlinux/extlinux.conf
    bootcmd_dhcp=devtype=dhcp; run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00010:UNDI:003000;setenv bootp_arch 0xa;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr -q ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
    bootcmd_mmc0=devnum=0; run mmc_boot
    bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
    bootcmd_qspi=run qspiload; run qspiboot
    bootdelay=2
    bootm_size=0xa000000
    bootmode=sd
    cpu=armv7
    distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
    efi_dtb_prefixes=/ /dtb/ /dtb/current/
    fatscript=if fatload mmc 0:1 ${scriptaddr} ${scriptfile};then source ${scriptaddr}; fi
    fdt_addr_r=0x02000000
    fdtcontroladdr=3bf74610
    fdtfile=socfpga_cyclone5_kfb_dual_sdram.dtb
    fpgatype=cv_se_a6
    kernel_addr_r=0x01000000
    load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
    loadaddr=0x01000000
    mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi
    mtdids=nor0=ff705000.spi.0
    prog_core=if load mmc 0:1 ${loadaddr} fit_spl_fpga.itb;then fpga loadmk 0 ${loadaddr}:fpga-core-1; fi
    pxefile_addr_r=0x02200000
    ramdisk_addr_r=0x02300000
    scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
    scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then part uuid ${devtype} ${devnum}:${distro_bootpart} distro_bootpart_uuid ; run scan_dev_for_boot; fi; done; setenv devplist
    scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;run boot_efi_bootmgr;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootarm.efi; then echo Found EFI removable media binary efi/boot/bootarm.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile
    scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo EXTLINUX FAILED: continuing...; fi
    scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
    scriptaddr=0x02100000
    scriptfile=u-boot.scr
    soc=socfpga
    socfpga_legacy_reset_compat=1
    stderr=serial
    stdin=serial
    stdout=serial
    usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi
    vendor=qmtech
    ver=U-Boot 2024.07-36780-g67806ba5853-dirty (May 09 2026 - 16:08:17 +0300)
    Environment size: 4441/8188 bytes
    => fatls mmc 0:1
      6275664   zImage
                extlinux/
      2082772   soc_system.rbf
        25844   socfpga_cyclone5_kfb_dual_sdram.dtb
    3 file(s), 1 dir(s)
    => load mmc 0:1 ${loadaddr} soc_system.rbf;
    2082772 bytes read in 111 ms (17.9 MiB/s)
    => fpga load 0 ${loadaddr} $filesize;
     I've attached  a zip which contains a full boot log, defconfig and .config file produced after building U-Boot. Also pics of what my Quartus projects settings are - regarding the generated and used .rbf file.
    FYI, I've tried several MSEL Dip Sw settings : "00000" and "01010" but nothing works.
    Please advise :?
    -Monk
    YoshiakiS_Altera
    Hello monkstein88,
    We apologize for the inconvenience.
    I will check the original topic.
    Yoshiaki Saito
    monkstein88
    Greetings Yoshiaki,
    So, first, I actually tried something first yesterday after writing my original message and I have good results. In the Quartus project settings - I disabled the compression for the bitstream and also  set the Configuration scheme to Passive Parallel x16.
    Also, in the same project settings, I enabled the generation of the Raw Binary File (.rbf).
    So, now when the Quartus project  is rebuild (as normal) it will also create the .rbf file I need for U-boot. Then I recompiled the project, and just used to .sof file to program directly the FPGA part of the device:
    And it was all successful. Actually, the FPGA portion of the design contains a Qsys, that features several different JTAG masters and JTAG Uart. And after the design (.sof) was programmed -  those became visible when polling the jtagconfig with the USB-Blaster still attached:
    Thus, the configuration files (.sof) and (.rbf) - match and work with the SoC FPGA on the board correctly. Note: At this point the produced .sof and .rbf files are 'uncompressed' and configured for 'FPP x16'.
    monkstein88
    Then, I took the .rbf file (from the prev post) and put in (overwriting the older .rbf file) to the FAT partion of the SD Card, and set the MSEL [4:0] = '00000' (All are  'ON' )   , and powered up the board. And this time there were no errors when loading the .rbf.
    U-Boot SPL 2024.07-36780-g67806ba5853-dirty (May 09 2026 - 16:08:17 +0300)
    DRAM:  1 GiB
    Core:  29 devices, 15 uclasses, devicetree: separate
    In:    serial
    Out:   serial
    Err:   serial
    Model: QMTECH C5SOC KFB Dual SDRAM
    Net:
    Error: ethernet@ff702000 No valid MAC address found.
    No ethernet found.
    => fpga info
    Altera Device
    Family:         SoC FPGA
    Cookie:         0x0 (0)
    => fatls mmc 0:1
      6275664   zImage
                extlinux/
      7007204   soc_system.rbf
    3 file(s), 1 dir(s)
    => oad mmc 0:1 ${loadaddr} soc_system.rbf;
    Unknown command 'oad' - try 'help'
    7007204 bytes read in 363 ms (18.4 MiB/s)
    And after the .rbf was loaded, the JTAG nodes showed up again when polled , through the NIOS shell with the USB Blaster:
    ~$ jtagconfig -n
    1) USB-Blaster [1-4]
      4BA00477   SOCVHPS
      02D020DD   5CSEBA6(.|ES)/5CSEMA6/..
        Design hash    385F96C94BBA3F772A79
        + Node 0C206E00  JTAG PHY #0
        + Node 0C206E01  JTAG PHY #1
        + Node 0C206E02  JTAG PHY #2
        + Node 0C006E00  JTAG UART #0
        + Node 00486E00  Source/Probe #0
    So, at this point, I have a functioning FPGA configuration loading when UBooting. Note this is with uncompressed bitstream files.
    I guess the next thing that remains to check - is why and how to make the original attempt with compressed bitstream file (.rbf) to work :?
  • Wow! I wasn't expecting that resolution!  Great job debugging, both of you! Board problems can be so difficult to find!
    Sue
