A topic explaining a problem with Cyclone V SoC - u-booting .rbf file failure - got rejected.
- 6 months ago
Hello Yoshiaki,
Thank you so much for taking the effort to test the .rbf files I built and shared on your own DE10-Nano system, and confirming them that they actually work. :)
On my side, on my own QMTECH board, I did the check (performed the register read from U-Boot shell) of the 'stat' register of the FPGA Manager Module, and I think I found my answer/reason for my troubles. So I had set MSEL SW to '01010' (ON-OFF-ON-OFF-ON) on my board, stopped at U-Boot, issued the command and got the below:
=> md ff706000 1 ff706000: 00000058 X... =>So, I do NOT get the expected: 'ff706000: 00000050 P...' , but actually 'ff706000: 00000058 X...' . And then I checked my board physically , toggling one pin at a time , and then reading back the 'stat' register after each pin change. And it was found out that one of the pad pins (the PIN.5) of the DIP SW was broken. And toggling the one switch adjacent to that pin, made no change in the 'stat' register readout.
So, I think the cause had been found for why Uboot can't load compressed .rbf succesfully - my board has a broken MSEL DIP SW pin and it just physically cannot apply/provide the MSEL = '01010'. So, I have to fix my board in this case.
Anyway, at this point, I think the issue is to be considered SOLVED. You can close this ticket.
Much gratitutes Yoshiaki, you've been of great help!
- Monk M.
Ok, I will try to lay out the original problem I have been encountering.
Currently I am experiencing a persistent issue with a QMTech Cyclone V SoC board (a very close clone of the Terasic DE10-Nano Board), trying to load the fpga configuration (.rbf) while the board is booting (U-Boot). While the .rbf is being loaded, I get an error: 'Command 'load' failed: Error -6' .
Overall, the whole booting process works, my system is able to go through the whole process: UBoot SPL -> UBoot -> Linux (logjn prompt). But a phase in between - which is the FPGA configuration loading is failing.
Here's the U-Boot shell excerpt, where I prompt the system for a couple of things and then try to fpga load the .rbf file:
=> fpga info
Altera Device
Descriptor @ 0x3ffec7a0
Family: SoC FPGA
Interface type: Fast Passive Parallel (FPP)
Device Size: 4294967295 bytes
Cookie: 0x0 (0)
No Device Function Table.
=> printenv
arch=arm
baudrate=115200
board=c5soc-kfb-dual-sdram
board_name=c5soc-kfb-dual-sdram
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootarm.efi; if fdt addr -q ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
boot_efi_bootmgr=if fdt addr -q ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr;fi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf}
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_syslinux_conf=extlinux/extlinux.conf
boot_targets=mmc0 qspi pxe dhcp
bootcmd=load mmc 0:1 ${loadaddr} soc_system.rbf && fpga load 0 ${loadaddr} $filesize; sysboot mmc 0:1 any ${scriptaddr} /extlinux/extlinux.conf
bootcmd_dhcp=devtype=dhcp; run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00010:UNDI:003000;setenv bootp_arch 0xa;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr -q ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_mmc0=devnum=0; run mmc_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootcmd_qspi=run qspiload; run qspiboot
bootdelay=2
bootm_size=0xa000000
bootmode=sd
cpu=armv7
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
efi_dtb_prefixes=/ /dtb/ /dtb/current/
fatscript=if fatload mmc 0:1 ${scriptaddr} ${scriptfile};then source ${scriptaddr}; fi
fdt_addr_r=0x02000000
fdtcontroladdr=3bf74610
fdtfile=socfpga_cyclone5_kfb_dual_sdram.dtb
fpgatype=cv_se_a6
kernel_addr_r=0x01000000
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
loadaddr=0x01000000
mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi
mtdids=nor0=ff705000.spi.0
prog_core=if load mmc 0:1 ${loadaddr} fit_spl_fpga.itb;then fpga loadmk 0 ${loadaddr}:fpga-core-1; fi
pxefile_addr_r=0x02200000
ramdisk_addr_r=0x02300000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then part uuid ${devtype} ${devnum}:${distro_bootpart} distro_bootpart_uuid ; run scan_dev_for_boot; fi; done; setenv devplist
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; if test -z "${fdtfile}" -a -n "${soc}"; then setenv efi_fdtfile ${soc}-${board}${boardver}.dtb; fi; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;run boot_efi_bootmgr;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootarm.efi; then echo Found EFI removable media binary efi/boot/bootarm.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo EXTLINUX FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
scriptaddr=0x02100000
scriptfile=u-boot.scr
soc=socfpga
socfpga_legacy_reset_compat=1
stderr=serial
stdin=serial
stdout=serial
usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi
vendor=qmtech
ver=U-Boot 2024.07-36780-g67806ba5853-dirty (May 09 2026 - 16:08:17 +0300)
Environment size: 4441/8188 bytes
=> fatls mmc 0:1
6275664 zImage
extlinux/
2082772 soc_system.rbf
25844 socfpga_cyclone5_kfb_dual_sdram.dtb
3 file(s), 1 dir(s)
=> load mmc 0:1 ${loadaddr} soc_system.rbf;
2082772 bytes read in 111 ms (17.9 MiB/s)
=> fpga load 0 ${loadaddr} $filesize;
=>I've attached a zip which contains a full boot log, defconfig and .config file produced after building U-Boot. Also pics of what my Quartus projects settings are - regarding the generated and used .rbf file.
FYI, I've tried several MSEL Dip Sw settings : "00000" and "01010" but nothing works.
Please advise :?
-Monk
