12 years ago
ALU in VHDL newbi having some major issues
Hi guys, I need to serious help over here. I need to code an ALU that can perform different function base on the op code, add, subtract, logical shift left and right.
namely these:
https://www.alteraforum.com/forum/attachment.php?attachmentid=8404
Now my main problem right now is.. i have no clue how to implement the condition statements correctly so that I can pick and choose what operation I need to perform. I think i managed to code an full adder/subtract r.. but I dont know how to implement it under a condition .. keep getting compile time errors if i try anything... I want to keep everything in one file.. i dont want to use packages.. Can some one please help me!? this is what I have so far.. it compiles as is, but the comments will tell you my struggles..
LIBRARY ieee ;
USE ieee.std_logic_1164.all ;
ENTITY fulladd IS
    PORT ( a, b, cin : IN STD_LOGIC ;
            s, cout : OUT STD_LOGIC ) ;
END fulladd ;
ARCHITECTURE LogicFunc OF fulladd IS
BEGIN
    s <= a XOR b XOR cin ;
    Cout <= (a AND b) OR (cin AND a) OR (cin AND b) ;
END LogicFunc ;
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
USE ieee.std_logic_unsigned.ALL;
--USE work.fulladd package.all ;
ENTITY alu IS
--GENERIC ( n : INTEGER := 32 );
PORT(
    a         : IN  STD_LOGIC_VECTOR(31 DOWNTO 0);
    b         : IN  STD_LOGIC_VECTOR(31 DOWNTO 0);
    cin   : IN  STD_LOGIC;
    S     : OUT STD_LOGIC_VECTOR(31 DOWNTO 0); --sum
    cout     : OUT STD_LOGIC;
    op     : IN  STD_LOGIC_VECTOR( 2 DOWNTO 0);
    zero     : OUT STD_LOGIC);
END ENTITY alu;
--ARCHITECTURE description OF alu IS BEGIN
-- You fill in what goes here!!!! END description;
--process(all)
--begin
               architecture LogicFunc of alu is
                        signal c : std_logic_vector(0 to 30); -- internal carry signals
                        begin
                        a0: entity WORK.fulladd port map(a(0), b(0), cin, S(0), c(0));
                        stage: for I in 1 to 30 generate
                            as: entity WORK.fulladd port map(a(I), b(I), c(I-1) , S(I), c(I));
                        end generate stage;
                        a31: entity WORK.fulladd port map(a(31), b(31), c(30) , S(31), cout);
                    end architecture LogicFunc;
         --       architecture LogicFunc of alu is
            --            signal c : std_logic_vector(0 to 30); -- internal carry signals
            --            begin
            --            a0: entity WORK.fulladd port map(a(0), b(0), cin, S(0), c(0));
            --            stage: for I in 1 to 30 generate
            --                as: entity WORK.fulladd port map(a(I), b(I), c(I-1) , S(I), c(I));
            --            end generate stage;
            --            a31: entity WORK.fulladd port map(a(31), b(31), c(30) , S(31), cout);
            --        end architecture LogicFunc;
--end process;
--END description;
--ARCHITECTURE Structure OF alu IS
--    SIGNAL C : STD_LOGIC_VECTOR(0 TO n) ;
--    COMPONENT fulladd
--        PORT ( Cin, x, y : IN  STD_LOGIC ;
--                    s, Cout : OUT STD_LOGIC ) ;
--    END COMPONENT ;
--BEGIN
--    C(0) <= Cin ;
--    Generate_label:
--    FOR i IN 0 TO n&#8722;1 GENERATE
--        stage: fulladd PORT MAP ( C(i), a(i), b(i), result(i), C(i+1)) ;
--    END GENERATE;
--    Cout <= C(32) ;
--END Structure;
--stage0: fulladd PORT MAP ( Cin, a(0), b(0), S(0), C(1) ) ;
--stage1: fulladd PORT MAP ( C(1), a(1), b(1), S(1), C(2) ) ;
--stage3: fulladd PORT MAP ( C(2), a(2), b(2), S(2), C(3) ) ;
--stage4: fulladd PORT MAP ( C(3), a(3), b(3), S(3), C(4) ) ;
--stage5: fulladd PORT MAP ( C(4), a(4), b(4), S(4), C(5) ) ;
--stage6: fulladd PORT MAP ( C(5), a(5), b(5), S(5), C(6) ) ;
--stage7: fulladd PORT MAP ( C(6), a(6), b(6), S(6), C(7) ) ;
--stage8: fulladd PORT MAP ( C(7), a(7), b(7), S(7), C(8) ) ;
--stage9: fulladd PORT MAP ( C(8), a(8), b(8), S(8), C(9) ) ;
--stage10: fulladd PORT MAP ( C(9), a(9), b(9), S(9), C(10) ) ;
--stage11: fulladd PORT MAP ( C(10), a(10), b(10), S(10), C(11) ) ;
--stage12: fulladd PORT MAP ( C(11), a(11), b(11), S(11), C(12) ) ;
--stage13: fulladd PORT MAP ( C(12), a(12), b(12), S(12), C(13) ) ;
--stage14: fulladd PORT MAP ( C(13), a(13), b(13), S(13), C(14) ) ;
--stage15: fulladd PORT MAP ( C(14), a(14), b(14), S(14), C(15) ) ;
--stage16: fulladd PORT MAP ( C(15), a(15), b(15), S(15), C(16) ) ;
--stage17: fulladd PORT MAP ( C(16), a(16), b(16), S(16), C(17) ) ;
--stage18: fulladd PORT MAP ( C(17), a(17), b(17), S(17), C(18) ) ;
--stage19: fulladd PORT MAP ( C(18), a(18), b(18), S(18), C(19) ) ;
--stage20: fulladd PORT MAP ( C(19), a(19), b(19), S(19), C(20) ) ;
--stage21: fulladd PORT MAP ( C(20), a(20), b(20), S(20), C(21) ) ;
--stage22: fulladd PORT MAP ( C(21), a(21), b(21), S(21), C(22) ) ;
--stage23: fulladd PORT MAP ( C(22), a(22), b(22), S(22), C(23) ) ;
--stage24: fulladd PORT MAP ( C(23), a(23), b(23), S(23), C(24) ) ;
--stage25: fulladd PORT MAP ( C(24), a(24), b(24), S(24), C(25) ) ;
--stage26: fulladd PORT MAP ( C(25), a(25), b(25), S(25), C(26) ) ;
--stage27: fulladd PORT MAP ( C(26), a(26), b(26), S(26), C(27) ) ;
--stage28: fulladd PORT MAP ( C(27), a(27), b(27), S(27), C(28) ) ;
--stage29: fulladd PORT MAP ( C(28), a(28), b(28), S(28), C(29) ) ;
--stage30: fulladd PORT MAP ( C(29), a(29), b(29), S(29), C(30) ) ;
--stage31: fulladd PORT MAP ( C(30), a(30), b(30), S(30), C(31) ) ;
--stage32: fulladd PORT MAP ( C(31), a(31), b(31), S(31), cout ) ;
--END Structure ;
please help me!
oh and I can't use add or subtract operator, must be using logic gates.
