12 years agook thanks again Tricky!!..
Now I'm getting some other error for the code below. There is something wrong with my port mapping loop. Error (10028): Can't resolve multiple constant drivers for net "result[31]" at alu.vhd(48) Error (10029): Constant driver at alu.vhd(52) Error (10028): Can't resolve multiple constant drivers for net "result[30]" at alu.vhd(48) Error (10028): Can't resolve multiple constant drivers for net "result[29]" at alu.vhd(48) Error (10028): Can't resolve multiple constant drivers for net "result[28]" at alu.vhd(48) Error (10028): Can't resolve multiple constant drivers for net "result[27]" at alu.vhd(48) Error (10028): Can't resolve multiple constant drivers for net "result[26]" at alu.vhd(48) Error (10028): Can't resolve multiple constant drivers for net "result[25]" at alu.vhd(48)
LIBRARY ieee ;
USE ieee.std_logic_1164.all ;
ENTITY fulladd IS
PORT ( Cin, x, y : IN STD_LOGIC ;
s, Cout : OUT STD_LOGIC ) ;
END fulladd ;
ARCHITECTURE LogicFunc OF fulladd IS
BEGIN
s <= x XOR y XOR Cin ;
Cout <= (x AND y) OR (Cin AND x) OR (Cin AND y) ;
END LogicFunc ;
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
USE ieee.std_logic_unsigned.ALL;
ENTITY alu IS
PORT(
a : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
b : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
op : IN STD_LOGIC_VECTOR( 2 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR(31 DOWNTO 0); -- in place of result
cout : OUT STD_LOGIC;
zero : OUT STD_LOGIC);
END alu;
ARCHITECTURE description OF alu IS
-- you fill in what goes here!!!
COMPONENT fulladd
END COMPONENT ;
SIGNAL C : STD_LOGIC_VECTOR(0 TO 32) ;
-- SIGNAL a1:STD_LOGIC_VECTOR (31 DOWNTO 0) ;
-- SIGNAL b1:STD_LOGIC_VECTOR (31 DOWNTO 0) ;
-- SIGNAL result1:STD_LOGIC_VECTOR (31 DOWNTO 0) ;
BEGIN
C(0) <= op(2) ;
Generate_label:
FOR i IN 0 TO 32-1 GENERATE
stage: fulladd PORT MAP ( C(i), a(i), b(i), result(i), C(i+1)) ;
END GENERATE;
Cout <= C(32) ;
PROCESS (op,a,b,C)
BEGIN
IF op="000" THEN
result <= a AND b;
ELSIF op="001" THEN
result <= a OR b;
ELSIF op="010" THEN
--result <= a + b;
ELSIF op="110" THEN
result <= a - b;
ELSIF op="100" THEN
--result <= a << 1;
ELSIF op="101" THEN
--result <= b >> 1;
END IF;
END PROCESS;
END description;
Also, how the heck would I actually call the adder from the corresponding if statement?? Sorry my prof thinks we should know VHDL somehow, from our past lives I guess..
