cjak's avatar
cjak
5 months ago
Timing analysis - long combinational path
Running Timing Analyzer I get violations due to long combinational paths. Looking at the path in the technology map viewer, it looks like this
leftmost block = registerbank holding a configurable value used by the other two modules
center/rightmost block = two identical modules using the register-value
I can see the long path, but I do not understand why it is implemented like this. Why is the register-value routed through dec_filter:15 to dec_filter:9, and not getting the value directly from the register-bank-module to the left?
Is there anything I can do to force a different implementation?
  • sstrell's avatar
    sstrell
    Without seeing the code and just going by the names on the logic, you're performing a number of math operations and comparisons on the source signal, adding additional levels of logic.  Reviewing and adjusting the RTL code would probably be the easiest solution.  Post some code.
  • ShengN_altera's avatar
    ShengN_altera
    Try to add more pipeline register to shorten the combinational path
  • cjak's avatar
    cjak
      p_filter_fsm : process (clk) is
      begin
        if rising_edge(clk) then
          if (rst = '1') then
            coef_addr_cnt            <= i_config_filterlength_reg(coef_addr_cnt'range) - 1;
            decimation_cnt           <= (others => '0');
            accRAM_addr_in           <= i_config_q_factor_reg(accRAM_addr_in'range) - 1;
            prev_accRAM_addr_in      <= i_config_q_factor_reg(accRAM_addr_in'range) - 1;
            accRAM_addr_out          <= i_config_q_factor_reg(accRAM_addr_out'range) - 1;
            prev_accRAM_addr_out     <= i_config_q_factor_reg(accRAM_addr_out'range) - 1;
            run_filter_cnt           <= (others => '0');
            we_accRAM                <= '0';
            accRAM_Re_out_add        <= (others => '0');
            accRAM_Im_out_add        <= (others => '0');
            filtered_accRAM_addr_out <= (others => '0');
            o_filtered_sample.tvalid <= '0';
            o_filtered_sample.tlast  <= '0';
            state_filter             <= NEXT_SAMPLE;
          else
            -- Defaults
            accRAM_Re_out_add        <= accRAM_Re_out;
            accRAM_Im_out_add        <= accRAM_Im_out;
            we_accRAM                <= '0';
            o_filtered_sample.tdata(4*GC_CH_DATA_WIDTH-1 downto 0) <= (others => '0');
            -- FSM
            case state_filter is
              when NEXT_SAMPLE =>
                accRAM_addr_in  <= prev_accRAM_addr_in;
                accRAM_addr_out <= prev_accRAM_addr_out;
                we_accRAM       <= '0';
                if (sample_tvalid_posedge = '1') then
                  sample_in      <= sample_s1.tdata(GC_CH_DATA_WIDTH-1 downto 0);
                  coef_addr_cnt  <= coef_addr_cnt - to_integer(i_config_d_factor_reg);
                  decimation_cnt <= decimation_cnt + 1;
                  state_filter   <= FILTERING;
                end if;
              when FILTERING =>
                mult_Re     <= std_logic_vector(resize(signed(sample_in) * signed(i_coef_data(2*GC_COEF_DATA_WIDTH-1 downto GC_COEF_DATA_WIDTH)), mult_Re'length));
                mult_Im     <= std_logic_vector(resize(signed(sample_in) * signed(i_coef_data(GC_COEF_DATA_WIDTH-1 downto 0)), mult_Im'length));
                mult_Re_ext <= std_logic_vector(resize(signed(mult_Re), mult_Re_ext'length));
                mult_Im_ext <= std_logic_vector(resize(signed(mult_Im), mult_Im_ext'length));
                -- Truncate number of bits defined in 'config_lsb_prod_reg'
                case i_config_lsb_prod_reg(2 downto 0) is
                  when b"000" =>
                    add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH-1 downto 0);  -- (35:0)
                    add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH-1 downto 0);
                  when b"001" =>
                    add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH downto 1);    -- (36:1)
                    add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH downto 1);
                  when b"010" =>
                    add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH+1 downto 2);  -- (37:2)
                    add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH+1 downto 2);
                  when b"011" =>
                    add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH+2 downto 3);  -- (38:3)
                    add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH+2 downto 3);
                  when b"100" =>
                    add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH+3 downto 4);  -- (39:4)
                    add_Im_in <= mult_Im_ext(GC_ADDER_WIDTH+3 downto 4);
                  when others =>
                    add_Re_in <= mult_Re_ext(GC_ADDER_WIDTH-1 downto 0);  -- same as (b"000")
                end case;
                -- Counter for controlling length of Filtering-state
                run_filter_cnt <= run_filter_cnt + 1;
                -- Read previous sum from accRAM
                if (run_filter_cnt > i_config_q_factor_reg-1) then
                  accRAM_addr_out <= filtered_accRAM_addr_out;
                elsif (run_filter_cnt > 0) then
                  -- Rotating accRAM-address counter for reading from accRAM
                  if (accRAM_addr_out = 0) then
                  else
                    accRAM_addr_out <= accRAM_addr_out - 1;
                  end if;
                end if;
                -- Add new sum and store in accRAM
                if (run_filter_cnt > C_START_WRITING_NEW_SUM+i_config_q_factor_reg) then
                  we_accRAM <= '0';
                elsif (run_filter_cnt > C_START_WRITING_NEW_SUM) then
                  we_accRAM    <= '1';
                  accRAM_Re_in <= std_logic_vector(signed(add_Re_in) + signed(accRAM_Re_out_add));
                  accRAM_Im_in <= std_logic_vector(signed(add_Im_in) + signed(accRAM_Im_out_add));
                  if (run_filter_cnt > C_START_WRITING_NEW_SUM+1) then
                    -- Rotating accRAM-address counter for writing to accRAM
                    if (accRAM_addr_in = 0 and we_accRAM = '1') then
                    else
                      accRAM_addr_in <= accRAM_addr_in - 1;
                    end if;
                  end if;
                end if;
                -- Update address-counter for coef-RAM, until last overlap is reached
                if (run_filter_cnt < i_config_q_factor_reg-1) then
                  if (coef_addr_cnt < i_config_d_factor_reg) then
                  else
                  end if;
                end if;
                -- Control length of FILTERING-state
                if (run_filter_cnt = i_config_q_factor_reg+8) then
                  if (decimation_cnt < i_config_d_factor_reg) then
                    coef_addr_cnt <= i_config_filterlength_reg(coef_addr_cnt'range) -1 -decimation_cnt;  -- coef in first overlap
                  elsif (decimation_cnt = i_config_d_factor_reg) then
                    state_filter <= FILTER_OUTPUT;
                  end if;
                end if;
              when FILTER_OUTPUT =>
                o_filtered_sample.tdata  <= accRAM_Re_Out & accRAM_Im_out;
                o_filtered_sample.tvalid <= '1';
                if (i_config_q_factor_reg = 1) then
                elsif (filtered_accRAM_addr_out > i_config_q_factor_reg-2) then
                else
                  filtered_accRAM_addr_out <= filtered_accRAM_addr_out + 1;
                end if;
                -- Flush cell which is read, in accRAM
                we_accRAM      <= '1';
                accRAM_addr_in <= filtered_accRAM_addr_out;
                accRAM_Re_in   <= (others => '0');
                accRAM_Im_in   <= (others => '0');
                -- Update coefficient for next sample
                -- Reset decimation counter
                -- Store accRAM-address value for next round of filtering before
                -- changing state
                prev_accRAM_addr_in  <= accRAM_addr_in;
                prev_accRAM_addr_out <= accRAM_addr_out;
              when others => state_filter <= NEXT_SAMPLE;
            end case;
          end if;
        end if;
      end process p_filter_fsm;
    Here are the filter statemachin which uses the config_q_factor:
  • sstrell's avatar
    sstrell
    This code isn't showing any of the signal processing from your screenshot.  Where is dec_filter?
  • cjak's avatar
    cjak
    Yes, this is the filter. Both multiply and accumulate happens in the FILTERING-state, along with truncation. In addition, there is a RAM holding the accumulated sum. Input-samples are not stored when coming in.
      o_coef_addr <= std_logic_vector(coef_addr_cnt);
      -- Accumulator RAM
      p_accRAM : process (clk) is
      begin
          if (we_accRAM = '1') then
            accRAM_Re(to_integer(accRAM_addr_in)) <= accRAM_Re_in;
            accRAM_Im(to_integer(accRAM_addr_in)) <= accRAM_Im_in;
          end if;
          accRAM_Re_out <= accRAM_Re(to_integer(accRAM_addr_out));
          accRAM_Im_out <= accRAM_Im(to_integer(accRAM_addr_out));
        end if;
      end process p_accRAM;
      -- Sample input-samples and detect tvalid-flanks
      p_edge : process (clk) is
      begin
          sample_s1.tvalid <= i_sample.tvalid;
          sample_s1.tdata  <= i_sample.tdata;
          if (i_sample.tvalid = '1' and sample_s1.tvalid = '0') then
            sample_tvalid_posedge <= '1';
            sample_tvalid_negedge <= '0';
          elsif (i_sample.tvalid = '0' and sample_s1.tvalid = '1') then
            sample_tvalid_negedge <= '1';
            sample_tvalid_posedge <= '0';
          else
          end if;
        end if;
      end process p_edge;
  • sstrell's avatar
    sstrell
    A few things.
    You have way too much logic in your state machine.  The next state logic should simply determine the conditions for switching state (determined in separate processes or elsewhere) and specify what the next state should be.  Setting outputs in particular states should be in their own separate non-clocked process so the appropriate output appears as soon as you move to the new state.  If you're reliant on some logic within a state to then determine a new value before then assigning an output, that's going to cause timing issues.  Create additional states to give yourself extra clock cycles or pull that logic out.  Assignments like these that rely on other logic within the same filtering state are probably the issue and should be in separate combinatorial processes:
    Sticking to_integer and signed functions in there doesn't help matters either.
  • cjak's avatar
    cjak
    Thanks for the feedback. I will look into rewriting the statemachine next week.
    But, how do you go about to avoid type-casting/conversion like to_integer/signed?
    • sstrell's avatar
      sstrell
      That may not necessarily be the issue.  Try cleaning up your state machine first.
  • cjak's avatar
    cjak
    Hi, I rewrote my state-machine, but I did not achieve much increase in performance.
    Adding multicycle-path statement on a "semi-static" configuration-registers caused the Fmax to go up, but I still have violations related to the filter. The calculations have been extracted from the state-machine as shown in the code below.
    The timing analyzer still complains about long combinational paths. The process below calculates on every clock-cycle. Would it be a solution to added extra pipeline-registers in between the calculation stages, and add multicycle-statements to relax the timing requirement?
      p_filter_calculations : process (clk) is
      begin
          -- Multiplication of input sample with coefficients
            when b"000" =>
            when b"001" =>
            when b"010" =>
            when b"011" =>
            when b"100" =>
            when others =>
          end case;
          if (run_filter_cnt > C_START_WRITING_NEW_SUM and
              run_filter_cnt < C_START_WRITING_NEW_SUM+i_config_q_factor_reg+1) then
          elsif (next_state = FILTER_OUTPUT) then
          end if;
        end if;
      end process p_filter_calculations;
      ShengN_altera
      It's better to add some pipeline register in the state machine. Too high logic level combinational path is not recommended for high performance design because combinational path cannot be retimed.
      I think timing will improve a lot after adding pipeline register.
  • cjak's avatar
    cjak
    Thanks, but I believe I have tried that too. I still get violations related to the calculations
    Is there something fundamental I have misunderstood about FSMs? or maybe Quartus TA?
    My FSM now looks like this:
      -- Filter statemachine
      -- Avoid start filtering in the "middle" of tvalid, if reset is released at a
      -- bad time => need both negative edge and a positive edge on the next tvalid
      -- in order to start filtering.
      begin
          if (rst = '1') then
            current_state <= IDLE;
          else
            current_state <= next_state;
          end if;
        end if;
      -- Counters for handling accRAM-accesses during filtering
      p_filter_fsm_counters : process (clk) is
      begin
          if (rst = '1') then
            sample_in                <= (others => '0');
          else
            -- Defaults
            case current_state is
              when IDLE =>
              when NEXT_SAMPLE =>
                if (sample_tvalid_posedge = '1' or sample_tvalid_negedge = '1') then
                end if;
              when FILTERING =>
                  else
                  end if;
                end if;
                  end if;
                end if;
                  else
                  end if;
                end if;
                if (run_filter_cnt > C_START_WRITING_NEW_SUM+1 and
                  else
                  end if;
                end if;
                else
                end if;
                -- changing state
              when others => null;
            end case;
          end if;
        end if;
      end process p_filter_fsm_counters;
      -- Asynchronous FSM outputs
      p_filter_fsm_outputs : process (all) is
      begin
        -- Defaults
        next_state <= current_state;
          when IDLE =>
            next_state <= NEXT_SAMPLE;
          when NEXT_SAMPLE =>
              next_state <= FILTERING;
            else
            end if;
          when FILTERING =>
                next_state <= FILTER_OUTPUT;
              end if;
            else
            end if;
          when others => next_state <= NEXT_SAMPLE;
        end case;
      end process p_filter_fsm_outputs;
      -- FSM pipeline stage
      p_fsm_pipelining : process (clk) is
      begin
          if (rst = '1') then
            we_accRAM                                              <= '0';
          else
            -- Defaults
            we_accRAM                                              <= '0';
              when IDLE =>
              when FILTERING =>
                  we_accRAM <= '0';
                  we_accRAM <= '1';
                end if;
                we_accRAM                <= '1';
            end case;
          end if;
        end if;
      end process p_fsm_pipelining;
      -- Filter-calculations, synchronous
      begin
          -- Resizing of vectors
            when b"001" =>
            when b"010" =>
            when b"011" =>
            when b"100" =>
            when others =>
          end case;
          end if;
        end if;
      ShengN_altera
      Could you try retime stage report and fast forward timing closure report for the path that need register check below:
      • cjak's avatar
        cjak
        I use Quartus Prime Lite Edition. I suspect I do not have access to the reports mentioned?
      ShengN_altera
      Does your problem resolved? Do you need further help? If yes, possible provide your project file?
      • cjak's avatar
        cjak
        No, I have not achieved timing closure, and the redesigned filter seem to achieve a lower fmax than the original implementation. Unfortunately I cannot share the design.
