Invalid license key (inconsistent authentication code)
Hi Team,
Getting below error. Kindly help to resolve it.
15:19:33 (alterad) Using options file: "port"
15:19:33 (alterad) Invalid license key (inconsistent authentication code)
15:19:33 (alterad) ==>FEATURE ip_video_image_suite alterad 2026.07 14-jul-2026 1 \
- ShengN_altera
Could you re-setup the server fully follows the steps in this link Know-How: Set Up a Floating License (Step-by‑Step Walkthrough) | Altera Community - 352000
- dshetty
We bought redundant server setup license but currently using single server setup. Is that be an issue?
- ShengN_altera
Should be no problem. Could you re-run all the steps from the link posted before?
- ShengN_altera
Check this KDB (alterad) Invalid license key (inconsistent authentication code) | Altera Community - 338161
Redundant server you must use all server and cannot comment out.
- dshetty
And also please suggest how to check the port number from user machine where application installed.
- ShengN_altera
License configuration details below:
SERVER xxxxxxxx xxxxxxx 27000
#SERVER <hostname> 0050568F1133<port number>
DAEMON alterad C:\Flexlm\Maxplus\alterad.exe -port=27001 please follow this Know-How: Set Up a Floating License (Step-by‑Step Walkthrough) | Altera Community - 352000 step 2 format:
this line DAEMON alterad C:\Flexlm\Maxplus\alterad.exe -port=27001 seen weird. Port number can use random number not repeat with your pc port number. I suggest using 8888
- dshetty
Getting same error after changing port number.
