Synthesis error
I generated HDL file from qsys and did the compilation in Quartus. Following error log was found:
Error(13224): Verilog HDL or VHDL error at altpcieav_256_rp_rxm_rdwr.sv(287): index 3 is out of range [31:5] for 'addr'
Error(13224): Verilog HDL or VHDL error at altpcieav_256_rp_rxm_txctrl.sv(196): index 4 is out of range [1:0] for 'tx_data'
Error(13224): Verilog HDL or VHDL error at altpcieav_256_rp_txs.sv(196): index 95 is out of range [65:0] for 'rx_fifo_data'
Error(13224): Verilog HDL or VHDL error at altpcieav_256_rp_app.sv(597): index 257 is out of range [71:0] for 'rx_fifo_dataq'
Error(16851): Verilog HDL error at udh_en0.sv(127): formal port avs0 of type avlmm_ifc' from library 'function_enet_20 does not match with actual type avlmm_ifc' from library 'ast2avmm_pcie_bridge_hw_191
Error(16851): Verilog HDL error at udh_en0.sv(125): formal port avs1 of type avlmm_ifc' from library 'function_enet_20 does not match with actual type avlmm_ifc' from library 'ast2avmm_pcie_bridge_hw_191
Error(16851): Verilog HDL error at udh_en0.sv(123): formal port avs2 of type avlmm_ifc' from library 'function_enet_20 does not match with actual type avlmm_ifc' from library 'ast2avmm_pcie_bridge_hw_191
Error(16851): Verilog HDL error at udh_en0.sv(122): formal port avs3 of type avlmm_ifc' from library 'function_enet_20 does not match with actual type avlmm_ifc' from library 'ast2avmm_pcie_bridge_hw_191
Error(16851): Verilog HDL error at udh_en0.sv(121): formal port avm0 of type avlmm_ifc' from library 'function_enet_20 does not match with actual type avlmm_ifc' from library 'ast2avmm_pcie_bridge_hw_191
Error(16851): Verilog HDL error at udh_en0.sv(119): formal port mdio_r of type mdio_ifc' from library 'function_enet_20 does not match with actual type mdio_ifc' from library 'altera_work
Error(16851): Verilog HDL error at udh_en0.sv(120): formal port mdio_s of type mdio_ifc' from library 'function_enet_20 does not match with actual type mdio_ifc' from library 'altera_work
Error(16851): Verilog HDL error at udh_en0.sv(118): formal port mdio_t of type mdio_ifc' from library 'function_enet_20 does not match with actual type mdio_ifc' from library 'altera_work
Error(16851): Verilog HDL error at hssl_i.sv(130): formal port avs of type avlmm_ifc' from library 'function_hssl_20 does not match with actual type avlmm_ifc' from library 'ast2avmm_pcie_bridge_hw_191
Error(16851): Verilog HDL error at hssl_i.sv(127): formal port avm0 of type avlmm_ifc' from library 'function_hssl_20 does not match with actual type avlmm_ifc' from library 'ast2avmm_pcie_bridge_hw_191
Error(16851): Verilog HDL error at hssl_i.sv(128): formal port gmii_r of type gmii_ifc' from library 'function_hssl_20 does not match with actual type gmii_ifc' from library 'function_enet_20
Error(16851): Verilog HDL error at hssl_i.sv(129): formal port gmii_s of type gmii_ifc' from library 'function_hssl_20 does not match with actual type gmii_ifc' from library 'function_enet_20
Error(16851): Verilog HDL error at hssl_i.sv(131): formal port gmii_t of type gmii_ifc' from library 'function_hssl_20 does not match with actual type gmii_ifc' from library 'function_enet_20
Error(16851): Verilog HDL error at hssl_i.sv(125): formal port mdio_r of type mdio_ifc' from library 'function_hssl_20 does not match with actual type mdio_ifc' from library 'altera_work
Error(16851): Verilog HDL error at hssl_i.sv(126): formal port mdio_s of type mdio_ifc' from library 'function_hssl_20 does not match with actual type mdio_ifc' from library 'altera_work
Error(16851): Verilog HDL error at hssl_i.sv(124): formal port mdio_t of type mdio_ifc' from library 'function_hssl_20 does not match with actual type mdio_ifc' from library 'altera_work
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(380): formal port gmii0 of type gmii_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type gmii_ifc' from library 'function_enet_20
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(382): formal port gmii1 of type gmii_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type gmii_ifc' from library 'function_enet_20
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(377): formal port gmii2 of type gmii_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type gmii_ifc' from library 'function_enet_20
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(378): formal port gmii3 of type gmii_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type gmii_ifc' from library 'function_enet_20
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(374): formal port gmii4 of type gmii_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type gmii_ifc' from library 'function_enet_20
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(376): formal port gmii5 of type gmii_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type gmii_ifc' from library 'function_enet_20
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(372): formal port gmii6 of type gmii_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type gmii_ifc' from library 'function_enet_20
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(373): formal port gmii7 of type gmii_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type gmii_ifc' from library 'function_enet_20
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(370): formal port gmii8 of type gmii_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type gmii_ifc' from library 'function_enet_20
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(371): formal port gmii9 of type gmii_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type gmii_ifc' from library 'function_enet_20
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(366): formal port gmii10 of type gmii_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type gmii_ifc' from library 'function_enet_20
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(367): formal port gmii11 of type gmii_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type gmii_ifc' from library 'function_enet_20
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(391): formal port avs0 of type avlmm_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type avlmm_ifc' from library 'ast2avmm_pcie_bridge_hw_191
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(390): formal port avs1 of type avlmm_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type avlmm_ifc' from library 'ast2avmm_pcie_bridge_hw_191
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(387): formal port avs2 of type avlmm_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type avlmm_ifc' from library 'ast2avmm_pcie_bridge_hw_191
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(386): formal port avs3 of type avlmm_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type avlmm_ifc' from library 'ast2avmm_pcie_bridge_hw_191
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(389): formal port avs4 of type avlmm_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type avlmm_ifc' from library 'ast2avmm_pcie_bridge_hw_191
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(388): formal port avs5 of type avlmm_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type avlmm_ifc' from library 'ast2avmm_pcie_bridge_hw_191
Error(16851): Verilog HDL error at qsgmii2gmii_0.sv(383): formal port avs6 of type avlmm_ifc' from library 'QSGMII_to_GMII_Bridge_10 does not match with actual type avlmm_ifc' from library 'ast2avmm_pcie_bridge_hw_191
Error(16186): Can't elaborate top-level user hierarchy
Error: Flow failed:
Error: Quartus Prime Synthesis was unsuccessful. 65 errors, 191 warnings
Error: Peak virtual memory: 1041 megabytes
Error: Processing ended: Wed Sep 23 11:02:52 2026
Error: Elapsed time: 00:01:58
Error: System process ID: 23412
Error(293001): Quartus Prime Full Compilation was unsuccessful. 67 errors, 191 warnings
It seems the instantiated avlmm(for instance) is trying to map to the same module in altera_work which gneerates this error. How do i solve it?
- ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
- sstrell
Does your Platform Designer system generate successfully when you generate it manually?
- Vishnu_Ajith
sstrell Yes it does. Although some warnings were there it did generate. One more point to be added is the files were developed on 20.3 version and I am using 21.3. But I did see the synthesis report of previous compilation and it showed 21.3. Is the simulation version sensitive?
- ShengN_altera
Hi
Any further update does your problem had been resolved?
- ShengN_altera
May I know is this your custom rtl code?
- sstrell
So are you saying that this did compile successfully at one point and now it doesn't?
And what does simulation have to do with this? Are we talking about compiling in Quartus or compiling for simulation in a simulation tool like Questasim?
