Invalid license key (inconsistent authentication code)
We bought redundant server setup license but currently using single server setup. Is that be an issue?
Should be no problem. Could you re-run all the steps from the link posted before?
- dshetty4 months ago
Yes ,
Getting error that :The desired vendor daemon is down
License configuration details below:
SERVER xxxxxxxx xxxxxxx 27000
#SERVER <hostname> 0050568F1133<port number>
DAEMON alterad C:\Flexlm\Maxplus\alterad.exe -port=27001
Log file:
5:55:46 (lmgrd) Starting vendor daemon at port 27001
5:55:46 (lmgrd) Using vendor daemon port 27001 specified in license file
5:55:46 (lmgrd) Started alterad (pid 6912)
5:55:46 (alterad) FlexNet Licensing version v11.11.1.0 build 116574 x64_n6
5:55:46 (alterad) lmgrd version 11.16, alterad version 11.11
5:55:46 (alterad) Using options file: "-port="5:55:46 (alterad) Invalid license key (inconsistent authentication code)
5:55:46 (alterad) ==>FEATURE ip_video_image_suite alterad 2026.07 14-jul-2026 1 \
- ShengN_altera4 months ago
Have you edit the license file? Could you re-generate the license file and see?
Edited to update the port and daemon path. Re-generate from where ?
