12 years agoHey guys, let me try that again. I started from scratch. here is my code now.
Now I have the full adder sitting up there, can someone please tell me how I correctly port map the variables under the condition for adding, and use the adder that is. I can not use the plus or minus operator like I did there, and it must be asynchronous. Thanks
LIBRARY ieee ;
USE ieee.std_logic_1164.all ;
ENTITY fulladd IS
PORT ( Cin, x, y : IN STD_LOGIC ;
s, Cout : OUT STD_LOGIC ) ;
END fulladd ;
ARCHITECTURE LogicFunc OF fulladd IS
BEGIN
s <= x XOR y XOR Cin ;
Cout <= (x AND y) OR (Cin AND x) OR (Cin AND y) ;
END LogicFunc ;
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
USE ieee.std_logic_unsigned.ALL;
ENTITY alu IS
PORT(
a : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
b : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
op : IN STD_LOGIC_VECTOR( 2 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
cout : OUT STD_LOGIC;
zero : OUT STD_LOGIC);
END alu;
ARCHITECTURE description OF alu IS
-- you fill in what goes here!!!
-- SIGNAL a1:STD_LOGIC_VECTOR (31 DOWNTO 0) ;
-- SIGNAL b1:STD_LOGIC_VECTOR (31 DOWNTO 0) ;
-- SIGNAL result1:STD_LOGIC_VECTOR (31 DOWNTO 0) ;
BEGIN
PROCESS (op,a,b)
BEGIN
IF op="000" THEN
result <= a AND b;
ELSIF op="001" THEN
result <= a OR b;
ELSIF op="010" THEN
result <= a + b;
ELSIF op="110" THEN
result <= a - b;
ELSIF op="100" THEN
--result <= a << 1;
ELSIF op="101" THEN
--result <= b >> 1;
END IF;
END PROCESS;
END description;
