12 years agook never mind I resolved the issue, but I still don't understand how to actually add.. like how do I call the adder from the if statement??
LIBRARY ieee ;
USE ieee.std_logic_1164.all ;
ENTITY fulladd IS
PORT ( Cin, x, y : IN STD_LOGIC ;
s, Cout : OUT STD_LOGIC ) ;
END fulladd ;
ARCHITECTURE LogicFunc OF fulladd IS
BEGIN
s <= x XOR y XOR Cin ;
Cout <= (x AND y) OR (Cin AND x) OR (Cin AND y) ;
END LogicFunc ;
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
USE ieee.std_logic_unsigned.ALL;
ENTITY alu IS
PORT(
a : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
b : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
op : IN STD_LOGIC_VECTOR( 2 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR(31 DOWNTO 0); -- in place of result
cout : OUT STD_LOGIC;
zero : OUT STD_LOGIC);
END alu;
ARCHITECTURE description OF alu IS
-- you fill in what goes here!!!
COMPONENT fulladd
END COMPONENT ;
SIGNAL C : STD_LOGIC_VECTOR(0 TO 32) ;
SIGNAL sum : STD_LOGIC_VECTOR(31 DOWNTO 0);
BEGIN
C(0) <= op(2) ;
Generate_label:
FOR i IN 0 TO 31 GENERATE
stage: fulladd PORT MAP ( C(i), a(i), b(i), result(i), C(i+1)) ;
END GENERATE;
Cout <= C(32) ;
PROCESS (op,a,b)
BEGIN
IF op="000" THEN
sum <= a AND b;
ELSIF op="001" THEN
sum <= a OR b;
ELSIF op="010" THEN
--sum <= a + b;
ELSIF op="110" THEN
--sum <= a - b;
ELSIF op="100" THEN
--sum <= a << 1;
ELSIF op="101" THEN
--sum <= b >> 1;
END IF;
END PROCESS;
END description;
since I don't know how to call the component I tried this, but don't work either!
--LIBRARY ieee ;
--USE ieee.std_logic_1164.all ;
--ENTITY fulladd IS
-- PORT ( Cin, x, y : IN STD_LOGIC ;
-- s, Cout : OUT STD_LOGIC ) ;
--END fulladd ;
--ARCHITECTURE LogicFunc OF fulladd IS
--BEGIN
-- s <= x XOR y XOR Cin ;
-- Cout <= (x AND y) OR (Cin AND x) OR (Cin AND y) ;
--END LogicFunc ;
LIBRARY ieee;
ENTITY alu IS
PORT(
END alu;
--COMPONENT fulladd
--END COMPONENT ;
SIGNAL CIN : STD_LOGIC;
SIGNAL X : STD_LOGIC;
SIGNAL Y : STD_LOGIC;
SIGNAL C_OUT: STD_LOGIC;
BEGIN
--C(0) <= op(2) ;
-- Generate_label:
-- FOR i IN 0 TO 31 GENERATE
-- stage: fulladd PORT MAP ( C(i), a(i), b(i), result(i), C(i+1)) ;
-- END GENERATE;
-- Cout <= C(32) ;
PROCESS (op,a,b)
BEGIN
IF op="000" THEN
sum <= a AND b;
ELSIF op="001" THEN
sum <= a OR b;
ELSIF op="010" THEN
--sum <= a + b;
C(0) <= op(2) ;
FOR i IN 0 DOWNTO 31 LOOP
sum(i) <= a(i) XOR b(i) XOR C(i) ;
C_OUT <= (a(i) AND b(i)) OR (C(i) AND a(i)) OR (C(i) AND b(i)) ;
C(i+1)<=C_OUT;
END LOOP;
cout<=C(32);
result<=sum;
ELSIF op="110" THEN
--sum <= a - b;
ELSIF op="100" THEN
--sum <= a << 1;
ELSIF op="101" THEN
--sum <= b >> 1;
END IF;
END PROCESS;
END description;
