12 years ago --- Quote Start --- The problem is because you forgot to put C in the sensitivity list. Another problem is due to the behaviour of VHDL. Signals are only assign when a process finishes, so C_out will only be assigned from when i = 31. And so all the values of C = C_OUT at i = 31. To do what you want you need to make C_Out a variable, not a signal. Also, that is not modelsim, thats the quartus integrated simulator that is quite lacking. A testbench is a peice of VHDL code that instantiates your design under test and provides stimulus for the UUT inputs. Have a think about how to shift right. You cannot change the direction an array is declared. So using 0 to 31 will cause an error before you start. you need to use downto. --- Quote End --- Thanks again Trick, but this thing wont add, it will never add! lol hate my life ...
--LIBRARY ieee ;
--USE ieee.std_logic_1164.all ;
--ENTITY fulladd IS
-- PORT ( Cin, x, y : IN STD_LOGIC ;
-- s, Cout : OUT STD_LOGIC ) ;
--END fulladd ;
--ARCHITECTURE LogicFunc OF fulladd IS
--BEGIN
-- s <= x XOR y XOR Cin ;
-- Cout <= (x AND y) OR (Cin AND x) OR (Cin AND y) ;
--END LogicFunc ;
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
USE ieee.std_logic_unsigned.ALL;
ENTITY alu IS
PORT(
a : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
b : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
op : IN STD_LOGIC_VECTOR( 2 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR(31 DOWNTO 0); -- in place of result
cout : OUT STD_LOGIC;
zero : OUT STD_LOGIC);
END alu;
ARCHITECTURE description OF alu IS
-- you fill in what goes here!!!
--COMPONENT fulladd
--END COMPONENT ;
SIGNAL CIN : STD_LOGIC;
SIGNAL X : STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL Y : STD_LOGIC;
--SIGNAL C : STD_LOGIC_VECTOR(0 TO 32) ;
SIGNAL sum : STD_LOGIC_VECTOR(31 DOWNTO 0);
--variable cnt : integer := -1;
BEGIN
--C(0) <= op(2) ;
-- Generate_label:
-- FOR i IN 0 TO 31 GENERATE
-- stage: fulladd PORT MAP ( C(i), a(i), b(i), result(i), C(i+1)) ;
-- END GENERATE;
-- Cout <= C(32) ;
PROCESS (op,a,b)
VARIABLE C : STD_LOGIC_VECTOR(0 TO 32) ;
VARIABLE C_OUT: STD_LOGIC;
BEGIN
CASE op IS
WHEN "000" =>
result <= a AND b;
WHEN "001" =>
result <= a OR b;
WHEN "010" =>
--sum <= a + b;
C(0) := '0'; --op(2) ;
FOR i IN 0 DOWNTO 31 LOOP
sum(i) <= a(i) XOR b(i) XOR C(i) ;
C_OUT := (a(i) AND b(i)) OR (C(i) AND a(i)) OR (C(i) AND b(i)) ;
C(i+1):= C_OUT;
END LOOP;
cout<=C(32);
result<=sum;
WHEN "110" =>
--sum <= a - b;
--C(0) <= op(2) ; --if carry in is one wont it mess up the operation?
X <= ((NOT b) + 1);
C(0) := '0';
sum(i) <= a(i) XOR X(i) XOR C(i) ;
C_OUT := (a(i) AND X(i)) OR (C(i) AND a(i)) OR (C(i) AND X(i)) ;
C(i+1):=C_OUT;
END LOOP;
cout<=C(32);
--result<=sum(31 DOWNTO 0);
result<=sum;
WHEN "100" =>
--sum <= a << 1;
result <=a (30 DOWNTO 0) & '0';
WHEN "101" =>
--sum <= a >> 1; HOW DO I SHIFT RIGHT??
--result <=a (0 TO 31) & '0'; -- ahh no.
WHEN OTHERS =>
END CASE;
END PROCESS;
END description;
