12 years agoI don't get this, this code should add, I have one just like it for the adder alone and it adds, but mine does not, vhdl is definitely the worst langue ever.
code that works:
library IEEE;
use IEEE.STD_LOGIC_1164.all;
entity adder_4 is
port(
a : in STD_LOGIC_VECTOR(3 downto 0);
b : in STD_LOGIC_VECTOR(3 downto 0);
sum : out STD_LOGIC_VECTOR(4 downto 0)
end adder_4;
architecture adder4_arc of adder_4 is
begin
adder4 : process (a,b) is
variable s : std_logic_vector (4 downto 0);
begin
s(0) := '0';
for i in 0 to 3 loop
sum(i) <= a(i) xor b(i) xor s(i) ;
s(i+1) := (a(i) and b(i)) or (b(i) and s(i)) or (s(i) and a(i));
end loop;
sum(4) <= s(4);
end process;
end adder4_arc;
my code using the exact same logic, don't work : (
--LIBRARY ieee ;
--USE ieee.std_logic_1164.all ;
--ENTITY fulladd IS
-- PORT ( Cin, x, y : IN STD_LOGIC ;
-- s, Cout : OUT STD_LOGIC ) ;
--END fulladd ;
--ARCHITECTURE LogicFunc OF fulladd IS
--BEGIN
-- s <= x XOR y XOR Cin ;
-- Cout <= (x AND y) OR (Cin AND x) OR (Cin AND y) ;
--END LogicFunc ;
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
USE ieee.std_logic_unsigned.ALL;
ENTITY alu IS
PORT(
a : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
b : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
op : IN STD_LOGIC_VECTOR( 2 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
cout : OUT STD_LOGIC;
zero : OUT STD_LOGIC);
END alu;
ARCHITECTURE description OF alu IS
-- you fill in what goes here!!!
--COMPONENT fulladd
--END COMPONENT ;
SIGNAL CIN : STD_LOGIC;
SIGNAL X : STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL Y : STD_LOGIC;
--SIGNAL C : STD_LOGIC_VECTOR(0 TO 32) ;
SIGNAL sum : STD_LOGIC_VECTOR(31 DOWNTO 0);
--variable cnt : integer := -1;
BEGIN
--C(0) <= op(2) ;
-- Generate_label:
-- FOR i IN 0 TO 31 GENERATE
-- stage: fulladd PORT MAP ( C(i), a(i), b(i), result(i), C(i+1)) ;
-- END GENERATE;
-- Cout <= C(32) ;
PROCESS (op,a,b,X,CIN,sum)
VARIABLE C : STD_LOGIC_VECTOR(32 DOWNTO 0) ;
VARIABLE C_OUT: STD_LOGIC;
BEGIN
CASE op IS
WHEN "000" =>
result <= a AND b;
WHEN "001" =>
result <= a OR b;
WHEN "010" =>
--sum <= a + b;
C(0) := '0'; --op(2) ;
FOR i IN 0 DOWNTO 31 LOOP
--sum(i) <= a(i) XOR b(i) XOR C(i) ;
result(i) <= a(i) XOR b(i) XOR C(i) ;
C(i+1) := (a(i) AND b(i)) OR (C(i) AND a(i)) OR (C(i) AND b(i)) ;
--C(i+1):= C_OUT;
END LOOP;
cout<=C(32);
--result<=sum;
WHEN "110" =>
--sum <= a - b;
--C(0) <= op(2) ; --if carry in is one wont it mess up the operation?
X <= ((NOT b) + 1);
C(0) := '0';
sum(i) <= a(i) XOR X(i) XOR C(i) ;
C(i+1) := (a(i) AND X(i)) OR (C(i) AND a(i)) OR (C(i) AND X(i)) ;
--C_OUT := (a(i) AND X(i)) OR (C(i) AND a(i)) OR (C(i) AND X(i)) ;
--C(i+1):=C_OUT;
END LOOP;
cout<=C(32);
--result<=sum(31 DOWNTO 0);
result<=sum;
WHEN "100" =>
--sum <= a << 1;
result <=a (30 DOWNTO 0) & '0';
WHEN "101" =>
--sum <= a >> 1; HOW DO I SHIFT RIGHT??
--result <=a (0 TO 31) & '0'; -- ahh no.
WHEN OTHERS =>
END CASE;
END PROCESS;
END description;
