12 years agoThe problem is because you forgot to put C in the sensitivity list. Another problem is due to the behaviour of VHDL. Signals are only assign when a process finishes, so C_out will only be assigned from when i = 31. And so all the values of C = C_OUT at i = 31. To do what you want you need to make C_Out a variable, not a signal.
Also, that is not modelsim, thats the quartus integrated simulator that is quite lacking. A testbench is a peice of VHDL code that instantiates your design under test and provides stimulus for the UUT inputs. Have a think about how to shift right. You cannot change the direction an array is declared. So using 0 to 31 will cause an error before you start. you need to use downto.
