14 years agoTo build a FIFO using SRAM
I would like to build a DCFIFO using a SRAM chip on DE2-115. Any idea on where i should start? I know SRAM reads and writes on a different clock cycle as the dataIn and dataOut share the same bidirectional databus, but do you think i can increase the frequency by 2 times (based on spec sheet, max performance of my SRAM is 125MHz), meaning if my ADC data coming in at 60MHz, i am inputting data and outputting data to/from my SRAM on an alternate cycle at 120MHz. is it possible? if yes, what are the things i need to be concerned about? regards, Michael
