15 years agoTo build a FIFO using SRAM
Hi, I would like to build a DCFIFO using a SRAM chip on DE2-115. Any idea on where i should start? I know SRAM reads and writes on a different clock cycle as the dataIn and dataOut share t...
15 years ago --- Quote Start --- Err.. isn't the part on the DE2-115 a 10 ns access time part? IS61WV102416BLL-10 Anyway, it supports back to back write operation, so he can write at 100 or 125 MHz. --- Quote End --- From the user manual of Terasic, it says the SRAM has maximum performance of up to 125MHz under condition of standard 3.3V.... so i thought 1/125MHz = 8ns ?? no? And what do you mean by "back to back" ? how does it work? Michael
