15 years agoMultiplexer Output Glitching
Hi all,
I'm having trouble multiplexing a number of signals without the output glitching. The following 4 to 1 multiplexer with all the inputs connected to 1 shows the issue:module multiplexertest (
input wire a,b,c,d,
input wire s,t,
output wire q
assign q = (s) ?
((t) ? d : c) :
((t) ? b : a);
endmodule`timescale 1 ns / 100 ps
module multiplexertest_TB ();
reg a,b,c,d;
reg s,t;
wire q;
multiplexertest multiplexertest_inst
.a(a) , // input a_sig
.b(b) , // input b_sig
.c(c) , // input c_sig
.d(d) , // input d_sig
.s(s) , // input s_sig
.t(t) , // input t_sig
.q(q) // output q_sig
initial begin
a = 1;
b = 1;
c = 1;
d = 1;
s = 0;
t = 0;
end
always
# 40 s = !s;
endmodule
Two input multiplexers don't seem to suffer from this issue though that may just be luck. Now I can fully understand that the glitches are generated due to the LUT within the LE which causing this but I would have thought that there should be a way around it. I need the fastest possible input to output performance so registering the data is something I'm trying to avoid doing.
