15 years agoMultiplexer Output Glitching
Hi all, I'm having trouble multiplexing a number of signals without the output glitching. The following 4 to 1 multiplexer with all the inputs connected to 1 shows the issue: module mult...
15 years agoThat is the major problem with asynchronous logic and FPGAs: they are not made for each other. Almost all FPGAs are pure synchronous beasts. (Except Achronix and maybe some newer start-up).
You are right about those 12 LE's to implement the 4 to 1 hazard free mux. A 4 input LUT isn't that powerful: it only enables you to decode one of the 16 squares in the corresponding Karnaugh map. The code you propose to build a 2 to 1 mux is not hazard free:assign x = (t) ? d : c; will translate into
x = !t & c
| t & d
; Where the hazard elimination term "| a & b" is missing.
