15 years ago
Multiplexer Output Glitching
Hi all,
I'm having trouble multiplexing a number of signals without the output glitching. The following 4 to 1 multiplexer with all the inputs connected to 1 shows the issue:
module multiplexertest (
    input wire a,b,c,d,
    input wire s,t,
    output wire q
    assign q = (s) ?
                ((t) ? d : c) :
                ((t) ? b : a);
endmodule
`timescale 1 ns /  100 ps
module multiplexertest_TB ();
    reg a,b,c,d;
    reg s,t;
    wire q;
    multiplexertest multiplexertest_inst
        .a(a) ,    // input  a_sig
        .b(b) ,    // input  b_sig
        .c(c) ,    // input  c_sig
        .d(d) ,    // input  d_sig
        .s(s) ,    // input  s_sig
        .t(t) ,    // input  t_sig
        .q(q)     // output  q_sig
    initial begin
        a = 1;
        b = 1;
        c = 1;
        d = 1;
        s = 0;
        t = 0;
    end
    always
       # 40 s = !s;
endmodule
Two input multiplexers don't seem to suffer from this issue though that may just be luck.
Now I can fully understand that the glitches are generated due to the LUT within the LE which causing this but I would have thought that there should be a way around it. I need the fastest possible input to output performance so registering the data is something I'm trying to avoid doing.
    Of course I was wrong with the LUT, I should have thought a bit further ...
    This effectively supports your theory that you should be able to make a 4 to 1 mux with just 3 LEs (or a 2^n to 1 mux with (n+1)*n/2 LEs)
    The LUT will be glitch-free only it is purposely designed so. E.g. the TpHL is longer than the TpLH so that a 'one' disappearing overlaps the next 'one' appearing. The simulations tend to go along that line.
    Thanks vjAlter, a search came up with the following which explains what I mean better than I managed:
    http://www.alteraforum.com/forum/showpost.php?p=8506&postcount=7
    --- Quote Start ---
    --- Quote End ---
    That will depend on the design of the LUT. If it is AND -> OR or OR -> AND may mean that TpHL needs to be shorter than TpLH (if I understand their meaning correctly). No matter the crucial bit is that the LUTs are glitch free if one and only one input changes.
    Something I borrowed from our friends at Xilinx:
    this is the original link (http://www.castalk.com/ftopic12373.html)
    --- Quote Start ---
    Re: Xilinx LUT behavior question
    by Peter Alfke » Thu Dec 01, 2005 9:12 am
    Good question, often asked:
    No glitch, and that behavior is guaranteed by the decoding structure.
    Further, if you change two pins, and you know that the output is
    identical for all 4 permutations of these 2 bits, there also is no
    glitch.
    And you can stretch that to 3 pins, where all 8 permutations must give
    identical results to avoid a glitch, although this last one may be an
    unrealisticl situation.
    I have answered this particular question many times over the past 15
    years.
    Peter Alfke, Xilinx Applications
    --- Quote End ---
    and
    --- Quote Start ---
    by Peter Alfke » Fri Dec 02, 2005 9:15 am
    Just to get back to the original question (which was kind of academic):
    my answer still stands. The muxing inside the LUT is done by pass
    transistors, and the internal capacitance holds the value during
    non-overlapped switching. So: no glitches.
    Austin describes glitching in a more general sense, and then mentions
    on the delay differences of different LUT address inputs. Good info,
    but does not contradict my statement.
    Peter Alfke
    --- Quote End ---
    I just wonder if an Altera 'official' would explain us whether this is also the case for their products. I'm inclined to think it will be. All the simulations I have done yesterday and today point into that direction.
    --- Quote Start ---
    --- Quote End ---
    As vjAlter explained, Altera FPGAs (and I think, Xilinx and other other vendors as well) have no specific means to support asnychronous designs. There are only a few simple cases, where you can guarantee an unregistered LUT output to be glitch free.
    The above quoted statement is however addressing only a part of the problem. It's not sufficient to ask, how a LUT behaves in case of two (or more) simultaneously changing inputs. Due to routing delays, they don't change exactly simultaneously. So only, when all permutations of the changing bits keep the output state, it (hopefully) won't glitch.
    As long as you are able to restructure the decoder to achieve this situation, there's a chance to avoid glitches. This has been the case with the binary multiplexer tree from the start of this discussion. It can be build glitch free, but the synthesis tool optimizes the logic in a way, that glitches are created. In this, and only in this case, synthesis attributes can help to enforce a glitch free gate level structure.
    The other important hint in vjAlters statement is related to the tools. A synthesis tool, that knows about routing delays would be able to make certain (or possibly all?) asnychronous designs glitch free. But none of the common synthesis tools has this feature, because it's not made to support asynchronous operation.
    A long time ago, I worked with async logic. I think you either need to "hold" the present output or drive all outputs to zero for a period long enough for the inputs to resolve then enable the outputs.
    If you can find info on TTL (TI's 74xx series) flip-flops were designed to hold the present qout on the leading clock edge then qout could change at the trailing clock edge.
    Also I think that even tho input t changes, it causes two assigns to change and the race between those 2 are the source of the glitches.
    Async logic only works if glitches are eliminated and that usually involves generation of a delay to hold while changes resolve or drive to a quiescent state until changes resolve.
    Async designs usually stress bus transfers and comparing inputs to outputs to determine the duration of the input clock./gate.
    D FFs are used instead of latches because the double latching prevents propagation of glitches and metastable signals.
    hi
    interresting question, in fact aside mux case the question is : are LUT able to implement basic logic function (and, or) as with old TTL without glitch.
    This is clearly dependant of the LUT architecture which is unknown to me.
    Does the attribute "keep" that i use also actually safe ?
