K_ED_RD1's avatar
K_ED_RD1
5 months ago
Quartus Pro simulation libraries for Riviera Pro
Using Quartus Pro 25.1, when trying to use the simulation library compiler tool to generate simulation libraries for Riviera Pro, the following error appears:
Error: # ACOM: Error: COMP96_0001: Cannot find source file "c:/altera_pro/25.1/quartus/eda/sim_lib/altera_syn_attributes.vhd".
Checking the folder content, it seems there are several missing files.
This scenario has been reproduced in several machines.
Could you please help us to solve this?
  • Hi,
    did you install EDA Simulation Libraries (27 GB install file!)?
    Frank
  • FvM's avatar
    FvM
    Frank
  • KennyT_altera's avatar
    KennyT_altera
    Does it happened for Riviera Pro only? Did you check if Questasim also face the same problem?
    KennyT_altera
    Do you manage to try it on other tools?
    Also, looking into this, you can also try the command:
    1.3.3.2. Running the Simulation Library Compiler in a Terminal
    You can run the Intel® Quartus® Prime Simulation Library Compiler in a terminal without launching the Intel® Quartus® Prime software GUI.
    The following example command generates the Questasim compile.do simulation script that compiles all Verilog HDL simulation files for the specified Intel Agilex® 7 device family.
    quartus_sh –simlib_comp -family agilex7 -tool questasim \     -language verilog -gen_only -cmd_file compile.do
    To view all available command-line options, you can run the following command:
    quartus_sh --help=simlib_comp
    https://docs.altera.com/r/docs/683080/23.1/intel-quartus-prime-standard-edition-user-guide-third-party-simulation/the-intel-quartus-prime-simulation-library
  • K_ED_RD1's avatar
    K_ED_RD1
    Hi we have installed the EDA simulation libraries and we are now able to compile the simulation libraries.
    Thanks for the support!
