Quartus Pro simulation libraries for Riviera Pro
- 5 months ago
did you install EDA Simulation Libraries (27 GB install file!)?
Frank
Do you manage to try it on other tools?
Also, looking into this, you can also try the command:
1.3.3.2. Running the Simulation Library Compiler in a Terminal
You can run the Intel® Quartus® Prime Simulation Library Compiler in a terminal without launching the Intel® Quartus® Prime software GUI.
The following example command generates the Questasim compile.do simulation script that compiles all Verilog HDL simulation files for the specified Intel Agilex® 7 device family.
quartus_sh –simlib_comp -family agilex7 -tool questasim \ -language verilog -gen_only -cmd_file compile.do
To view all available command-line options, you can run the following command:
quartus_sh --help=simlib_comp
https://docs.altera.com/r/docs/683080/23.1/intel-quartus-prime-standard-edition-user-guide-third-party-simulation/the-intel-quartus-prime-simulation-library
