15 years agoMultiplexer Output Glitching
Hi all, I'm having trouble multiplexing a number of signals without the output glitching. The following 4 to 1 multiplexer with all the inputs connected to 1 shows the issue: module mult...
15 years ago --- Quote Start --- A 4 input LUT isn't that powerful: it only enables you to decode one of the 16 squares in the corresponding Karnaugh map. --- Quote End --- I don't follow you there. A 4 input LUT allows you implement all 16 squares in an arbitrary Karnaugh map which makes them very powerful and is why FPGAs are full of them.
