Schematics/layout for TerasIC SoCKit rev. D with Cyclone V
Greetings!
I am working with an ALTERA/TerasIC SoCKit development board for Cyclone V. I've downloaded the "SoCKit CD-ROM ( rev. D Hardware )" archive from www.terasic.com.tw, but it does not contain schematics or PCB layout files.
What I want to do is access ~8 GPIO pins on the board, but it does not have a GPIO header. So I can either solder to the mysterious "AD-DA HDR" connector plus some LEDs/switches, or connect to one of the 3 groups of pins on the wide HSMC (one has 20 differential pairs, the other two have 60 pins each) using a Samtek connector. To do that, I need to know how the pins on the SoCKit's PCB connectors map to the 5CSXFC6D6F31C6 IC's pads.
BTW, I really appreciate the board having pads for an Altera JTAG connector pads: EthernetBlaster can be used with it!
--A.
- sol
Quick update. Perhaps this could be useful to someone in the future.
I tried some hacks to move the project forward, such as using VGA's V/H sync pins as I/O [only VGA_VS works for some reason], tracing connections on the PCB [while many of these traces are easily visible & trackable on the bottom layer, turns out you cannot use dedicated differential SERDES I/O as GPIO on Cyclone V]... Also trying to mix and match schematics for HTG-SMC HCSM adapter [there is a terasIC's tool called SystemBuilder, which actually runs under WINE, to generate a Quartus project, including pinout for this adapter -- but is ultimately incorrect for my board], and schematics for Altera HSMC debug header (which actually has the correct connector). I did not succeed so far in actually mapping enough HSMC generic I/O pins to pads on the chip for my needs. I can keep trying, and I will win... but this wastes so much time. Wish there were schematics: the effort would be reduced 100x.
FWIW, I do not wish to solder to the pushbuttons or switches (4 of each on the FPGA [not CPU] side), because I/O impedances matter, plus the board has been loaned to me -- so I dare not solder to FPGA's pads on the bottom layer (which conveniently appear to be via-in-pad).
- AqidAyman_Altera
Have you managed to reach out someone from Terasic to get the schematics? I saw dandanlau offered a contact person from Terasic to reach out.
- dandanlau
I can connect you up with the TerASIC FAE for help. Please drop me a private message.
- sol
Yes, that is the board. I did check older downloads, no schematics to be found (and the older boards don't have the "AD-DA HDR").
Thanks for confirming that Terasic normally include schematics, sstrell. I have sent them an email, no response so far.
- ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
- sstrell
Assuming you're talking about this kit:
I don't have a direct answer, but it's highly unusual from my experience that Terasic does not include schematics. Have you tried contacting them or checked one of the older board rev downloads?
