15 years agoMultiplexer Output Glitching
Hi all, I'm having trouble multiplexing a number of signals without the output glitching. The following 4 to 1 multiplexer with all the inputs connected to 1 shows the issue: module mult...
15 years agoI couldn't keep from searching a bit deeper and went back to some 'old' textbooks.
I.e. what we call a glitch here is in effect called a 'logic hazard'. Making hazard free circuits for a single input changing is relatively easy by adding 'redundant' (at first sight) coverage terms. For a logic hazard free 2 to 1 mux it looks like this
y = !s & a
| s & b
| a & b
; Unfortunately the 3rd term eliminating the logic hazard will optimized away, so the equation becomes abit elaborate
wire gab , gcd , gabcd, hab, hcd , habcd , iab , icd , iabcd , rab , rcd/* synthesis keep*/ ;
assign gab = !s & a0 ;
assign hab = s & b0 ;
assign iab = a0 & b0 ;
assign rab = gab | hab | iab ;
assign gcd = !s & c0 ;
assign hcd = s & d0 ;
assign icd = c0 & d0 ;
assign rcd = gcd | hcd | icd ;
assign gabcd = !t & rab ;
assign habcd = t & rcd ;
assign iabcd = rab & rcd ;
assign q0 = gabcd | habcd | iabcd ;
This will generate a hazard-free 4 to 1 multiplexer for a single input change. It should be possible to harness a 2 to 1 mux with hazard-coverage into a single LUT, but we may need some help form Altera here to 'tame' the optimizer.
