16 years ago
Design portability on a cyclone
Good morning,
I've got a HDL design which run in RTL simulation.
This design run in gate level simulation with time modelisation on a stratix II or an arria II.
Howerver, it doesn't work on a cyclone (II or III) FPGA.
I don't know what to do ! It's the first time for me that a design work on RTL simulation, on gate level simulation for several device but not on a Cyclone II/III.
For information here is the result of the ressource utilization on stratix II :
Combinational ALUTs    5,491 / 72,768 ( 8 % )
Dedicated logic registers    4,037 / 72,768 ( 6 % )
Combinational ALUT usage by number of inputs
-- 7 input functions    29
-- 6 input functions    1400
-- 5 input functions    625
-- 4 input functions    600
-- <=3 input functions    2837
Combinational ALUTs by mode
-- normal mode    3957
-- extended LUT mode    29
-- arithmetic mode    1388
-- shared arithmetic mode    117
Logic utilization    7,961 / 72,768 ( 11 % )
-- Difficulty Clustering Design    Low
-- Combinational ALUT/register pairs used in final Placement    7168
-- Combinational with no register    3131
-- Register only    1677
-- Combinational with a register    2360
-- Estimated pairs recoverable by pairing ALUTs and registers as design grows    -260
-- Estimated Combinational ALUT/register pairs unavailable    1053
-- Unavailable due to unpartnered 7 LUTs    18
-- Unavailable due to unpartnered 6 LUTs    886
-- Unavailable due to unpartnered 5 LUTs    27
-- Unavailable due to LAB-wide signal conflicts    99
-- Unavailable due to LAB input limits    23
Total registers*      4,037 / 75,850 ( 5 % )
-- Dedicated logic registers    4,037 / 72,768 ( 6 % )
-- I/O registers    0 / 3,082 ( 0 % )
ALMs:  partially or completely used    4,263 / 36,384 ( 12 % )
Total LABs:  partially or completely used    585 / 4,548 ( 13 % )
User inserted logic elements     0
Virtual pins    0
I/O pins    168 / 535 ( 31 % )
-- Clock pins     12 / 16 ( 75 % )
Global signals     2
M512s    0 / 488 ( 0 % )
M4Ks    16 / 408 ( 4 % )
M-RAMs    1 / 4 ( 25 % )
Total block memory bits    223,096 / 4,520,448 ( 5 % )
Total block memory implementation bits    663,552 / 4,520,448 ( 15 % )
DSP block 9-bit elements    4 / 384 ( 1 % )
PLLs    0 / 6 ( 0 % )
Global clocks    2 / 16 ( 13 % )
Regional clocks    0 / 32 ( 0 % )
SERDES transmitters    0 / 118 ( 0 % )
SERDES receivers    0 / 118 ( 0 % )
JTAGs    0 / 1 ( 0 % )
ASMI blocks    0 / 1 ( 0 % )
CRC blocks    0 / 1 ( 0 % )
Remote update blocks    0 / 1 ( 0 % )
Average interconnect usage (total/H/V)    2% / 2% / 2%
Peak interconnect usage (total/H/V)    27% / 27% / 26%
Maximum fan-out node    CLK~clkctrl
Maximum fan-out    4076
Does anybody got ideas ?
    --- Quote Start ---
    During the compilation, I have "approximatily" the same message for the stratix and the cyclone. No interresting warning.
    I found one warning when I looked at the waves in ModelSim. The message is
    "There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es)". That's means I've got an issue with a multiplier ?
    thanks
    --- Quote End ---
    is an "X" in the output of the simulation ?
    Kind regards
    GPK
    thanks
    --- Quote Start ---
    The design that I try to implement on a cyclone is a JPEG encoder : http://opencores.org/project,mkjpeg. I have managed to quick compile and test this design on a stratix II but, to make it run on a cyclone seems to be quiet difficult.
    "the design doesn't react as my RTL simulation " means that the output JPEG file is incorrect when I run a cyclone gate level simulation. However, in RTL simulation and in gate level stratix II simulation the design work properly with a perfect JPEG file.
    The problem is that I didn't find anything interresting in the warning : it seems to be the same as the StratixII :
    - Inferred RAM
    - PINs warning
    - object assigned a value but never read
    - pass through logic have been added to match the read-during-write behavior
    Thank you for your help.
    (To make the design run on an Altera chip you have to change one thing : headerROM.v : reg[7:0] mem [1023:0] -> reg[7:0] mem [0:622])
    --- Quote End ---
    what about timing violations ? Did you constrain clocks, input delays etc ...
    Kind regard
    GPK
    --- Quote Start ---
    What kind of warnings did you get in your Cyclone project ?
    --- Quote End ---
    - Inferred RAM
    - PINs warning
    --- Quote Start ---
    I think did'nt understand your question... Here is what I've done :
    I compiled my HDL code for a cyclone II. I have made a gate level simulation with Altera-Modelsim thanks to the .vho and the .sdo files. It doesn't work : the design doesn't react as my RTL simulation.
    I have done the same with a stratix II and it works : the gate level simulation for the stratix II make the same result as RTL simulation.
    That's why I think my code can be fit in a FPGA, but it doesn't work on my cylconeII.
    I've answer to your question ?
    In anyway, thank you very much for your answer !
    --- Quote End ---
    can you explain more detailed what you mean with "the design doesn't react as my RTL simulation " ? What kind of warnings did you get in your Cyclone project ?
    Kind regards
    GPK
    --- Quote Start ---
    You right, there are no MRAM on the cyclone. However MRAM cannot be replace by M9K during synthesis ?
    I'll check wich part of my design use the MRAM in order to move it to M9K.
    If the fact that I use MRAM can make the design don't work, the same approach can be done for the DSP block ? I mean : there are no DSP block in cyclone ! (I thought that the synthesis use the multiplier with LE to make the same)
    Am I right ?
    --- Quote End ---
    Hi actris,
    did you run a synthesis for Cyclone devices starting from RTL ?
    Kind regards
    GPK
    Am I right ?
    There is one thing i see ....
    --- Quote Start ---
    --- Quote End ---
    I thought Cyclone II and III have only M9K Memory blocks and no M-RAM, isn't that only available with Stratix devices ?
    I haven't seen M-RAM on any Cyclone I-III project i have done.
