Serdes Behavior
We have a custom board using SDI with Cyclone 10 GX device.
For unknown reason, we found the Serdes can't locked to external signal after power on/off at about 10%.
We tried download sof once we found the serdes failed, but the status kept the same.
We check the power sequence and it met the requirement.
How can we clarify this issue.. whether it's power related or others.
- JLee25
Contributor
We are using SDI and have been tried STP several XCVR locked signal.
But not able to find any clue.
One thing strange is the chip EQ locked signal to FPGA should be "High" but it's "Low" in STP.
And the locked locates in IO bank.
- Farabi_Altera
Do you have further question?
regards,
Farabi
- anonimcs
Contributor
No I don't mean the CLKUSR specificly. I meant the clock that you're feeding to the serdes core. If CLKUSR is the clock fed to the serdes core, then the input clock should not be the issue here. I'd check the ports of the serdes core (I have no clue about your serdes config, if you're using DPA, bitslip or FIFO reset signals etc), those should give us a better hint. But since you're observing this issue intermittently, my bet is on signal integrity (or metastability)
- Farabi_Altera
Common Altera FPGA SerDes / Transceiver Behavior Issues & Solutions
Depending on the specific SerDes issue you are trying to resolve, here are the standard solutions for the most frequent issues reported in this area:
1. Transceiver Initialization / Staggered Resets in Simulation
- Observed Behavior: Multiple independent SerDes channels (e.g., PCS-Direct on Stratix 10 or Agilex) initialize at staggered times ("strabbing") rather than simultaneously, or channel 0 fails to start immediately .
- Root Cause & Solution: This is normal hardware behavior governed by the Transceiver Reset Scheduler (TRS). In simulation, enabling the Fast reset for simu option in the Native PHY / Transceiver IP configuration bypasses the TRS sequence and forces all channels to initialize simultaneously .
2. LVDS SERDES Timing Analysis & Constraints
- Observed Behavior: Timing violations or ignored set_input_delay constraints on LVDS SERDES receiver inputs in Non-DPA mode .
- Solution: For Non-DPA mode, do not manually constrain the data lines with set_input_delay. Instead, enter the RCCS (Receiver Channel-to-Channel Skew) parameter directly in the LVDS SERDES IP core parameter editor . The Quartus Timing Analyzer then automatically generates the required SDC constraints based on the device's sampling window (SW) and transmitter channel-to-channel skew (TCCS) .
3. DPA Lock Failures in Simulation
- Observed Behavior: In simulation of RX DPA-FIFO or Soft-CDR modes, rx_dpa_locked does not assert within the expected datasheet lock window.
- Solution: The behavioral simulation models for DPA require significantly more clock edges and simulation run time than the theoretical hardware lock time (often requiring $>8\text{–}10,\mu\text{s}$ of valid toggling data). Ensure your testbench supplies adequate transitions and runs past $10,\mu\text{s}$.
4. Reference Clock Pin Restrictions (Error 18694 / Error 12499)
- Observed Behavior: Fitter errors stating that the reference clock feeding the SERDES IP / PLL is not driven by a dedicated reference clock pin from the same I/O bank.
- Solution:
- Ensure the reference clock input is assigned to the dedicated reference clock pin belonging to the same I/O bank as the SERDES channels (for interfaces with $<23$ channels).
- If cascading from another PLL or bank is necessary, insert a dedicated I/O PLL configured in cascade mode to feed the SERDES PLL.
5. Hardware serdes_pll_locked Behavior in PCIe HIP
- Observed Behavior: Discrepancy between documentation and hardware regarding when serdes_pll_locked asserts relative to pin_perstn.
- Solution: In real hardware, serdes_pll_locked asserts after pin_perstn is released, not before . Older user guide diagrams that depicted serdes_pll_locked permanently high prior to reset release were corrected/clarified in later revisions .
Next Step
If your issue relates to a different behavior (such as data width mapping, CDR loss-of-lock, electrical idle/LFPS, or adaptation modes), please share the device family (e.g., Agilex 5/7, Stratix 10, Cyclone V/10), IP core name, and the specific symptoms or error messages.
- anonimcs
Contributor
The first question comes to my mind is 'is the clock going to the serdes IP stable?'
- JLee25
Contributor
When the issue happened, we found portion of the design is running well like Nios CPU and memory controller.
Any comments.
