16 years agoDesign portability on a cyclone
Good morning, I've got a HDL design which run in RTL simulation. This design run in gate level simulation with time modelisation on a stratix II or an arria II. Howerver, it doesn't work on ...
16 years agoYou right, there are no MRAM on the cyclone. However MRAM cannot be replace by M9K during synthesis ?
I'll check wich part of my design use the MRAM in order to move it to M9K. If the fact that I use MRAM can make the design don't work, the same approach can be done for the DSP block ? I mean : there are no DSP block in cyclone ! (I thought that the synthesis use the multiplier with LE to make the same) Am I right ?
