16 years agoDesign portability on a cyclone
Good morning, I've got a HDL design which run in RTL simulation. This design run in gate level simulation with time modelisation on a stratix II or an arria II. Howerver, it doesn't work on ...
16 years agoThe design that I try to implement on a cyclone is a JPEG encoder : http://opencores.org/project,mkjpeg. I have managed to quick compile and test this design on a stratix II but, to make it run on a cyclone seems to be quiet difficult.
"the design doesn't react as my RTL simulation " means that the output JPEG file is incorrect when I run a cyclone gate level simulation. However, in RTL simulation and in gate level stratix II simulation the design work properly with a perfect JPEG file. --- Quote Start --- What kind of warnings did you get in your Cyclone project ? --- Quote End --- The problem is that I didn't find anything interresting in the warning : it seems to be the same as the StratixII : - Inferred RAM - PINs warning - object assigned a value but never read - pass through logic have been added to match the read-during-write behavior Thank you for your help. (To make the design run on an Altera chip you have to change one thing : headerROM.v : reg[7:0] mem [1023:0] -> reg[7:0] mem [0:622]) Regards
