16 years agoDesign portability on a cyclone
Good morning, I've got a HDL design which run in RTL simulation. This design run in gate level simulation with time modelisation on a stratix II or an arria II. Howerver, it doesn't work on ...
16 years ago --- Quote Start --- You right, there are no MRAM on the cyclone. However MRAM cannot be replace by M9K during synthesis ? I'll check wich part of my design use the MRAM in order to move it to M9K. If the fact that I use MRAM can make the design don't work, the same approach can be done for the DSP block ? I mean : there are no DSP block in cyclone ! (I thought that the synthesis use the multiplier with LE to make the same) Am I right ? --- Quote End --- Hi actris, did you run a synthesis for Cyclone devices starting from RTL ? Kind regards GPK
