verna's avatar
verna
4 years ago
clock control signal problem on Cyclone V GT
I'm working with the Cyclone V GT development board.My design only needs to use frequency divider to get the signal, I tried to use 240MHz to divide the frequency and can get the signal successfully, instructed to change the input signal to be above 300MHz or 200MHz to divide the frequency, but I couldn't get the signal successfully. These are all within the control range of the crystal oscillator.
  • SyafieqS's avatar
    SyafieqS
    Understood. Let me know if there is any other concern at our end.
    • verna's avatar
      verna
      Hi SyafieqS,
      I will try this method. If this method is still unsuccessful, I may only use frequencies between 200MHz and 300MHz for frequency division, and I can only temporarily not use other frequencies for frequency division.
      Thank you tour suggest.
  • verna's avatar
    verna
    Hi SyafieqS,
    I still not solve this problem. There's not error suggest. The clock control block warning suggest is Warning (15846): ena port of Clock Buffer Block "ALTCLK_altclkctrl_9kh:ALTCLK_altclkctrl_9kh_component|sd1" is connected to GND.
  • SyafieqS's avatar
    SyafieqS
    Chuang,
    May I know if there is any update?
  • SyafieqS's avatar
    SyafieqS
    Hi Chuang,
    Is there any warning/error using the clock control block as suggested as you mentioned not able to do so?
    Or still not manage to achieve the frequency desire?
  • verna's avatar
    verna
    Hi, SyafieqS
    I tried the following method but it didn't work.
    I try to use Clock Control Block (ALTCLKCTRL) to wire my input port and output port wire my counter to divide use three port pin outputs, my output ports one of which is SMA_CLKOUT on cyclone v gt and the other two pin outputs of Terasic XTS-HSMC, so I use REFCLK_QL3_P of HSMC port B connected to the clock input pin.
  • SyafieqS's avatar
    SyafieqS
    Hi Chuang,
    • verna's avatar
      verna
      Hi SyafieqS,
      Sorry,I still don't understand how to use it.
      My project use Cyclone V GT REFCLK_QL3_P (X4) to input clock, because I use three ports to output one is on Cyclone V GT SMA_CLKOUT and the other use Terasic XTS-HSMC (HSMB_CLK_OUT_P2 and HSMB_CLK_OUT_N2).
