verna
4 years agoclock control signal problem on Cyclone V GT
I'm working with the Cyclone V GT development board.My design only needs to use frequency divider to get the signal, I tried to use 240MHz to divide the frequency and can get the signal successfully,...
SyafieqS
4 years agoHi Chuang,
Are you using a custom code clock divider or clock enable signal for this? You should use clock enable signal and refer to below link related to the implementation.
https://www.intel.com/content/www/us/en/docs/programmable/683375/current/clock-enable-signals.html
