AManj1's avatar
AManj1
7 years ago
parity checker with reset
my program is:
module detector (s_out, s_in, reset, clk);
input s_in, reset, clk;
output s_out;
reg s_out;
reg state;
parameter even=0,odd=1;
always@(posedge clk or reset)
begin
if(reset)
state<=even;
else
case(state)
0:begin
state<=s_in?odd:even;
s_out<=s_in?1:0;
end
1:begin
state<=s_in?even:odd;
s_out<=s_in?0:1;
end
default:state<=even;
endcase
end
endmodule
but the program is not working for most test cases...help
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    Could you elaborate in details? Do you mean compilation error? Could you provide the error message?
    • AManj1's avatar
      AManj1
      the program question is:
      It is required to implement a sequence detector that will accept a serial bit stream “s_in” in synchronism with the positive edge of a clock, and will generate a serial bit stream “s_out” as output. The next bit of “s_out” will be 1, if the number of 1’s in “s_in” seen so far is odd; it will be 0 otherwise. The state transition diagram will consist of two states indicating whether the number of 1’s seen so far is odd or even. A “reset” low signal is used to asynchronously initialize the state to the “even 1’s state”.
      my program:
      output s_out;
      reg s_out;
      reg state;
      begin
      if(!reset)
      state<=even;
      else
      case(state)
      0:begin
      s_out<=s_in?1:0;
      end
      1:begin
      s_out<=s_in?0:1;
      end
      endcase
      end
      endmodule
      result of testcases:
      Compilation : Passed
      Public Test Cases: 1 / 4
      Test Case 1
      Pass: (state = x, s_in = 0, reset = 0) => (state = 0, s_out = x, reset = 0)\n
      Passed
      Test Case 2
      Pass: (state = 0, s_in = 1, reset = 1) => (state = 1, s_out = 1, reset = 1)\n
      Fail: (state = x, s_in = 1, reset = 1) => (state != 0, s_out != x, reset != 1)\n
      Wrong Answer
      Test Case 3
      Pass: (state = 1, s_in = 1, reset = 1) => (state = 0, s_out = 0, reset = 1)\n
      Fail: (state = 0, s_in = 1, reset = 1) => (state != 1, s_out != 1, reset != 1)\n
      Wrong Answer
      Test Case 4
      Pass: (state = 1, s_in = 0, reset = 1) => (state = 1, s_out = 1, reset = 1)\n
      Fail: (state = 0, s_in = 0, reset = 1) => (state != 0, s_out != 0, reset != 1)\n
      Wrong Answer
    KhaiChein_Y_Intel
    In an Event Control in the HDL, you specified an Event Control that contains both double-edge events and single-edge events. You cannot include both event types in one Event Control.
    I edited the HDL and the simulation result is correct.
    • AManj1's avatar
      AManj1
      Thank you Sir. I just learned something new.But even after modification,some private test cases are wrong
      i will get an exact answer by tomorrow and will update the program here as soon as possible
    • AManj1's avatar
      AManj1
      output s_out;
      parameter EVEN=1'b0, ODD=1'b1;
      reg s_out, state;
      always @(posedge clk, reset)
      begin
      if (!reset)
      state <= EVEN;
      else begin
      case ({state,s_in})
      2'b00,2'b11: begin
      s_out <= 1'b0;
      state <= EVEN;
      end
      2'b01,2'b10: begin
      s_out <= 1'b1;
      state <= ODD;
      end
      endcase
      end
      end
      endmodule
      allthough i think its the same program in a different way!!!!!!
    • AManj1's avatar
      AManj1
      any idea on how to implement this program?
      Write a Verilog module to implement a 32-bit Booth’s multiplier using behavioural style. The module will take two 32-bit multiplier (“mpr”) and multiplicand (“mpd”) as inputs, and produce a 64-bit product (“prod”) as output. An active high input signal “start” is used to start the multiplication, and after completion of the multiplication, a signal “done” will be set to 1.and carry out the tasks at any individual stage including state transition in the failing edge of an input clock “clk”.
      The following module template must be used for implementation:
      module booth (mpr, mpd, prod, start, done, clk);
      input [31:0] mpr, mpd;
      input start, clk;
      output [63:0] prod;
      output done;
    KhaiChein_Y_Intel
    May I know the status? Have you resolved the first error with the HDL code I have attached earlier?
    For the second question, you may refer to a video published by Intel FPGA: Verilog HDL Basics
    https://www.youtube.com/watch?v=PJGvZSlsLKs. The video shows how to implement behavioural statement at 31:02mins.
    • AManj1's avatar
      AManj1
      yes the issue was resolved.
      Thank you.
    • AManj1's avatar
      AManj1
      the program i came up with is:
      input start, clk;
      output [63:0] prod;
      output done;
      integer i;
      reg [31:0] A, Q, M;
      reg Q_1;
      reg [5:0] count;
      initial
      begin
      A <= 32'b0;
      M <= mpd;
      Q <= mpr;
      Q_1 <= 1'b0;
      count <= 6'b100000;
      end
      always@(negedge clk)
      begin
      case ({Q[0], Q_1})
      2'b00 : {A, Q, Q_1}=A<<<Q<<<Q_1;
      2'b01 : begin
      A=A+M;
      end
      2'b10 : begin
      A=A-M;
      end
      2'b11:{A, Q, Q_1}=A<<<Q<<<Q_1;
      endcase
      count=count-1'b1;
      end
      assign prod = {A, Q};
      assign done = (count==0);
      endmodule
      no compilation errors but not working for these test cases:
      Test Case 1
      0
      Pass: (start = 1, mpr = 16, mpd = 10) => (clock cycles = 37, prod = 160, done = 1)\n
      Fail: (start = 1, mpr = 16, mpd = 10) => (clock cycles = 37, prod != X, done != 0)\n
      Wrong Answer
      Test Case 2
      1
      Pass: (start = 0, mpr = 16, mpd = 10) => (clock cycles = 37, prod = x, done = x)\n
      Fail: (start = 0, mpr = 16, mpd = 10) => (clock cycles = 37, prod != X, done != 0)\n
      Wrong Answer
      Test Case 3
      2
      Pass: (start = 1, mpr = 75, mpd = 20) => (clock cycles = 41, prod = 1500, done = 1)\n
      Fail: (start = 1, mpr = 75, mpd = 20) => (clock cycles = 41, prod != X, done != 0)\n
      Wrong Answer
      Test Case 4
      3
      Pass: (start = 1, mpr = 85, mpd = 60) => (clock cycles = 43, prod = 5100, done = 1)\n
      Fail: (start = 1, mpr = 85, mpd = 60) => (clock cycles = 43, prod != X, done != 0)\n
      Wrong Answer
    KhaiChein_Y_Intel
    It is glad to hear that the first issue was resolved.
    For the second issue, may I request the design file and simulation result?
