IsaacDeSantiago's avatar
IsaacDeSantiago
1 year ago
Unable to checkout 'intelqsimstarter' license
Hello! Good morning from here.
I downloaded Quartus Prime Version 24.1std.0 Build 1077 03/04/2025 SC Lite Edition and I'm having an issue when trying to run a Unversity Program VWF file. It displays the following error: Failure to obtain a Verilog simulation license. Unable to checkout 'intelqsimstarter' license.
I'm trying to use it for academic purpose, that's why I downloaded that version, because I thought it was free. Isn't that simulation included in the free plan? Is there any way to get a free license for that purpose?
  • Isaac,
    The Questa-Sim software requires a free license. Return to the Quartus Prime Lite download page and scroll down to the section labeled Additional Resources. You will see a bullet called "Request a License from the..."
    Now, with my students, I found we don't actually have to do that process. Instead, we have this workflow on Microsoft Windows:
    • Use Quartus --> Tools --> License Setup --> Get No Cost Licenses
    • After acquiring a license file, a confirmation dialog will appear with the pathname of the file. Mouse highlight and copy that path name.
    • Ensure Use LM_LICENSE_FILE_variable is checked in the same dialog box
    • Open the Command Prompt application.
    • In Command Prompt: setx LM_LICENSE_FILE <<paste in path>>
    • Reboot computer
    • Ensure the Use LM_LICENSE_FILE checkbox is checked. It should be prepopulated with your path name now.
  • Hello Isaac,
    Good day.
    Kindly do let me know if the previous reply by our Contributor helped you moved forward.
    Pavee
