parity checker with reset
Could you elaborate in details? Do you mean compilation error? Could you provide the error message?
- AManj17 years ago
the program question is:
It is required to implement a sequence detector that will accept a serial bit stream “s_in” in synchronism with the positive edge of a clock, and will generate a serial bit stream “s_out” as output. The next bit of “s_out” will be 1, if the number of 1’s in “s_in” seen so far is odd; it will be 0 otherwise. The state transition diagram will consist of two states indicating whether the number of 1’s seen so far is odd or even. A “reset” low signal is used to asynchronously initialize the state to the “even 1’s state”.
my program:
module detector (s_out, s_in, reset, clk);
input s_in, reset, clk;
output s_out;
reg s_out;
reg state;
parameter even=0,odd=1;
always@(posedge clk or reset)
begin
if(!reset)
state<=even;
else
case(state)
0:begin
state<=s_in?odd:even;
s_out<=s_in?1:0;
end
1:begin
state<=s_in?even:odd;
s_out<=s_in?0:1;
end
default:state<=even;
endcase
end
endmodule
result of testcases:
Compilation : Passed
Public Test Cases: 1 / 4
Test Case 1
Pass: (state = x, s_in = 0, reset = 0) => (state = 0, s_out = x, reset = 0)\n
Passed
Test Case 2
Pass: (state = 0, s_in = 1, reset = 1) => (state = 1, s_out = 1, reset = 1)\n
Fail: (state = x, s_in = 1, reset = 1) => (state != 0, s_out != x, reset != 1)\n
Wrong Answer
Test Case 3
Pass: (state = 1, s_in = 1, reset = 1) => (state = 0, s_out = 0, reset = 1)\n
Fail: (state = 0, s_in = 1, reset = 1) => (state != 1, s_out != 1, reset != 1)\n
Wrong Answer
Test Case 4
Pass: (state = 1, s_in = 0, reset = 1) => (state = 1, s_out = 1, reset = 1)\n
Fail: (state = 0, s_in = 0, reset = 1) => (state != 0, s_out != 0, reset != 1)\n
Wrong Answer
