12 years agoVHDL Variables: Is it combinational code inside a clocked process?
Hello all
Since the VHDL variables topic strikes as a little bit odd even to VHDL designers who have some experience I would like to ask about VHDL variables in order to clarify a few things. If we have the usual case of register A feeding register B through some combinational logic (registers in same clock domain) then, until now,when I needed to make some complicated combinational code to represent the combinational code between the two registers, I used to do it in another non-clocked process having as inputs the outputs of register stage A and the outputs of the combinational code feeding the input of register stage B. Then inside the clocked process of stage B assign the values of the input. I was wondering, in order to make the code more readable and maintanable, is it possible to use variables to implement the complicated combinational code inside the clocked process so that I do not have to use another non-clocked process? Since I havent found somewhere a clear answer about the use of variables, I wanted to ask, is that the purpose of existence of VHDL variables? Do variables exist in order simplify the writing of combinational code inside a clocked process? Note: If I used signals inside the clocked process to help me store intermediate results,that would lead to register inference which is not intended if the designer wants to implement pure combionational code inside the clocked process.
