12 years ago --- Quote Start --- You are right but I think it's a matter of readibility and avoiding mistakes. I find it more easy to read splitting the RTL into a combination process and a sequential process. So, no need for variable. when you need the _next value(comb) right away in the sequential process just use the LVALUE (next) in the decision making. It's always harder to spot errors in simulation using Variables and simulation/synthesis mismatch ocurrs more. YMMV --- Quote End --- I don't know of any mismatch between tools regarding variables as long as they conform to vhdl standards. One case when I need to use variable is modulo n accumulator when n is not power of 2. For example if I need to add 7 modulo 100. I need to prevent counter going > 99 so I need to use variable to check value of counter and force it:
variable count : integer range 0 to 99 := 0;
begin
if count > 99 then
count := count -100;
else
count := count + 7;
end if;
if you use signal then count will be > 99 for one sample. Here one cay use if (count + 7) > 99... but I prefer variable
