17 years agoIt adds 3 and subtracts 1 instead of adding just 1
Hi!
I'm pretty new with vhdl and Quartus II and maybe this question is too obvious, but I spent three days on it and I cannot understand yet why is not working... I made a silly program, just adding one to a number, and just send one bit to the output. I tried to simulate it. There are no errors on Analysis & Synthesis, and no errors on EDA Netlist Writer. But the simulation is wrong (I don't obtain what I should) 1. I make a reset and "nombre" should be "0101010101", instead it is "0000000". 2. It should add 1 to this variable at each rising edge clock. Instead sometimes it adds 3 and then subtracts 1. I cannot understand what's happening. I know it should be a really silly mistake from me, because this program is too simple, but I cannot find it. Moreover I've done a more complicated program and I had no problems. Can anybody help me, please? Hier there is the code: ------------------------------------------------------------------------ library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; library altera; use altera.altera_primitives_components.all; entity prova1 is port ( -- Input ports clk : in std_logic; reset : in std_logic; -- Output ports sortida : out std_logic ); end prova1; -- Library Clause(s) (optional) -- Use Clause(s) (optional) architecture arch_prova1 of prova1 is signal nombre : std_logic_vector(9 downto 0):="0101010101"; begin pr1: process(clk,reset,nombre) begin if reset='1' then nombre<="0101010101"; else if(rising_edge(clk)) then nombre<=nombre+1; else nombre<=nombre; end if; end if; end process pr1; -- Add the library and use clauses before the design unit declaration ff_sortida : DFF port map ( d => nombre(4), clk => clk, clrn => not(reset), prn => '1', q => sortida ); end arch_prova1;
