14 years ago
inout Std_logic_vector Signal Test
I am getting the following error by writting a testbench for Asynchrone SRAM and I have tried to solve this unsucessfully.Please any advice
error output:# ** Error: Z:/Prototyp/Development_Infos_Collection/LS4000_Development/HW/FPGA/Tutorial/Simulation/Projects/sram1024kx8/tsram1024kx8.vhd(12): (vcom-1136) Unknown identifier "std_logic_vector".
vhdl code:
             entity test_sram1024x8 is
Line 12    PORT ( D    : inout Std_logic_vector(7 downto 0));
             end;
architecture test of test_sram1024x8 is
COMPONENT sram1024x8
  port (A    : in Std_logic_vector(19 downto 0);
        D    : inout Std_logic_vector(7 downto 0);
        nCE : in std_logic;
        nCE2 : in std_logic;
        nWE : in std_logic;
        nOE : in Std_logic);
END COMPONENT ;
SIGNAL A   : bit := '0';
SIGNAL nCE : bit := '1';
SIGNAL nCE2   : bit := '1';
SIGNAL nWE : bit := '1';
SIGNAL nOE : bit := '0';
begin
dut : sram1024x8
   PORT MAP (
    A => A,
    D => D,
    nCE => nCE,
    nCE2 => nCE2,
    nWE => nWE,
    nOE => nOE );
--clock : PROCESS
   --begin
   --wait for 10 ns; clk  <= not clk;
--end PROCESS clock;
stimulus : PROCESS
   begin
   --A <= '1';
   wait for 5 ns; nCE   <= '0';
   wait for 5 ns; nCE2  <= '0';
   wait for 5 ns; nOE  <= '1';
   wait for 12 ns; nWE  <= '0';
   wait;
end PROCESS stimulus;
end test;
    Well the problem is you have not constrained the signal A (please read your errors)
    you need to give it a size. You can only constrain constants with an initialisation value.
    signal a : std_logic_vector(19 downto 0) := (others => '0');
    Hi guy,
    I have finished with my SRAM Modeling and now my concern is to know
    how to integrated the timing requirement of my future Cypress Module?
    Any Idea?
    What exactly are you refering to?
    Do you want to simulate the design with a Cypress model?
    Or do you need to build a memory controller.
    The previous code you posted is simply test code and not synthesisable. You will have to write a memory controller to get it to work in real hardware.
    The external memory I intend to implement in my FPGA Project is from CYPRESS(8-Mbit (1024 K × 8) Static RAM)
    Here is my controller :
    --- Quote Start ---
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_unsigned.all;
    use ieee.std_logic_arith.all;
    end;
    COMPONENT sram1024kx8
    nCE : in std_logic;
    nWE : in std_logic;
    END COMPONENT ;
    SIGNAL A : std_logic_vector(19 downto 0) := (others => '0');
    SIGNAL nCE : std_logic := '1';
    SIGNAL nCE2 : std_logic := '1';
    SIGNAL nWE : std_logic := '1';
    SIGNAL nOE : std_logic := '1';
    --SIGNAL D : std_logic_vector(7 downto 0):="00000000";
    begin
    dut : sram1024kx8 PORT MAP (
    A => A(19 downto 0),
    D => D(7 downto 0),
    nCE => nCE,
    nCE2 => nCE2,
    nWE => nWE,
    nOE => nOE );
    stimulus : PROCESS
    begin
    --A <= '0000';
    wait for 5 ns;
    --A <= (others => '0');
    --wait for 25 ns; -- Read Task
    nCE <= '0';
    nCE2 <= '0';
    nWE <= '0';
    --Write the value "i" at the address "i" for 10 clock cycles.
    for i in 0 to 10 loop
    A <= conv_std_logic_vector(i,20);
    D <= conv_std_logic_vector(i,8);
    wait for 10 ns;
    end loop;
    nOE<= '0';
    --Read the RAM for addresses from 0 to 20.
    wait for 10 ns;
    end loop;
    end test;
    --- Quote End ---
    Is that enough to fully control my Cypress SRAM?
    But there are also timing requirement on Cypress Datasheet?
    Please sorry I send the false one here is the rigth controller:
    entity sram1024kx8 is
            nCE : in std_logic;
            nWE : in std_logic;
    end;
    architecture Behaviour of sram1024kx8 is
        subtype Byte is Std_logic_vector(7 downto 0);
        type Mem is array (0 to 1048576 ) of byte;
        signal Memory: Mem := (others => Byte'(others=>'U'));
    begin
      process(A, D, nCE, nCE2, nWE, nOE)
      begin
        D <= (others => 'Z');
        if nCE='0' and nCE2='0' then
          if nOE = '0' then                  -- Read operation
            D <= Memory(To_Integer(unsigned(A))) after 10 ns;
          elsif nWE = '0' then               -- Write operation
            Memory(To_Integer(unsigned(A))) <= D;
          end if;
        end if;
      end process;
    end;
    be aware that "after" keywords only work in simulation. They will be ignored for synthesis.
    The code you currently had will create millions of latches (more than is avaiulable in any device) because of the way you are connecting to the memory. Memory in FPGAs has to be synchronous, so you will have to have a clock input and follow the templates for infering a RAM.
    This new code is not a controller, it is a RAM.
    Ok
    You are rigth but what I am wondering is the fact that I have a reference Design from Arrow interfacing with an external memory.
    Take a look below:
    There is no top level vhdl file specified (top_level_hdl_file "" ).
    It means they just wrote a _hw.tcl as interface to the external SRAM.
    What that means ? such a connection without specified SRAM Controller?
    package require -exact sopc 9.1#  | #  +-----------------------------------
    #  +-----------------------------------#  | module ext_ram_16#  |
    set_module_property DESCRIPTION "Interface to an IS61VPS102418A device"
    set_module_property NAME IS61VPS102418A
    set_module_property VERSION 1.0.0
    set_module_property INTERNAL false
    set_module_property GROUP "CycloneIV Starterkit Components"
    set_module_property AUTHOR "Arrow Electronics"
    set_module_property DISPLAY_NAME "IS61VPS102418A SRAM"
    set_module_property TOP_LEVEL_HDL_FILE ""
    set_module_property INSTANTIATE_IN_SYSTEM_MODULE false
    set_module_property EDITABLE true
    set_module_property ANALYZE_HDL TRUE#  | #  +-----------------------------------
    the SRAM controller could be part of their IP catalogue,, and the TCl connects it to the SRAM. TCL cannot be used directly to create an SRAM controller. It could generate the VHDL/verilog though.
    Are you sure its not a verilog file?
    I think you are rigth. Can you give me some advice how an asynchrone SRAM Controller looks like ? or what I should pay attention ?
    you wouldnt have an asynchronous SRAM controller because the SRAM is already synchronous.
