14 years agoPlease sorry I send the false one here is the rigth controller:
entity sram1024kx8 is
port (A : in Std_logic_vector(19 downto 0);
D : inout Std_logic_vector(7 downto 0);
nCE : in std_logic;
nCE2 : in std_logic;
nWE : in std_logic;
nOE : in Std_logic);
end;
architecture Behaviour of sram1024kx8 is
subtype Byte is Std_logic_vector(7 downto 0);
type Mem is array (0 to 1048576 ) of byte;
signal Memory: Mem := (others => Byte'(others=>'U'));
begin
process(A, D, nCE, nCE2, nWE, nOE)
begin
D <= (others => 'Z');
if nCE='0' and nCE2='0' then
if nOE = '0' then -- Read operation
D <= Memory(To_Integer(unsigned(A))) after 10 ns;
elsif nWE = '0' then -- Write operation
Memory(To_Integer(unsigned(A))) <= D;
end if;
end if;
end process;
end;
