14 years agoThe external memory I intend to implement in my FPGA Project is from CYPRESS(8-Mbit (1024 K × 8) Static RAM)
Here is my controller : --- Quote Start --- library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.std_logic_arith.all; entity test_sram1024x8 is PORT ( D : inout Std_logic_vector(7 downto 0)); end; architecture test of test_sram1024x8 is COMPONENT sram1024kx8 port (A : in Std_logic_vector(19 downto 0); D : inout Std_logic_vector(7 downto 0); nCE : in std_logic; nCE2 : in std_logic; nWE : in std_logic; nOE : in Std_logic); END COMPONENT ; SIGNAL A : std_logic_vector(19 downto 0) := (others => '0'); SIGNAL nCE : std_logic := '1'; SIGNAL nCE2 : std_logic := '1'; SIGNAL nWE : std_logic := '1'; SIGNAL nOE : std_logic := '1'; --SIGNAL D : std_logic_vector(7 downto 0):="00000000"; begin dut : sram1024kx8 PORT MAP ( A => A(19 downto 0), D => D(7 downto 0), nCE => nCE, nCE2 => nCE2, nWE => nWE, nOE => nOE ); stimulus : PROCESS begin --A <= '0000'; wait for 5 ns; --A <= (others => '0'); --wait for 25 ns; -- Read Task nCE <= '0'; nCE2 <= '0'; nWE <= '0'; --Write the value "i" at the address "i" for 10 clock cycles. for i in 0 to 10 loop A <= conv_std_logic_vector(i,20); D <= conv_std_logic_vector(i,8); wait for 10 ns; end loop; nOE<= '0'; --Read the RAM for addresses from 0 to 20. for i in 0 to 10 loop A <= conv_std_logic_vector(i,20); wait for 10 ns; end loop; end PROCESS stimulus; end test; --- Quote End --- Is that enough to fully control my Cypress SRAM? But there are also timing requirement on Cypress Datasheet?
