11 years ago
How to use ip-generate on a hierarchical sys system
I am using ip-generate to compile a Qsys design into Verilog code than can be programmed into the FPGA and test benches for simulation. I have a single level Qsys system working, but my primary target has several qsys subsystems within a top level Qsys system. Can I use ip-generate directly to compile the hierarchical Qsys system? Do you have any example scripts which show how to do that? My current script reports the underlying sys sub-systems are "not found" even if I actually copy them to the local dir.
If the hierarchical project cannot be compiled in one go with ip-generate as can be done by the GUI. What is the recommended multi-step process and what are the recommended intermediate targets for a Makefile?
Thanks Martin
ps. I don’t see arguments to direct ip-generate to create a test bench but I did see an example which seemed to use a testbench specific .qsys file. !? What’s the best way to use ip-generate to creat a testbecnh from a .qsys system?
    I don't know the answer to the hierarchy question, but I have a suggestion that might work ...
    To determine what arguments to pass to ip-generate, I use the GUI and then copy the ip-generate arguments into a script, eg., this BeMicroCV design has an example for the DDR controller (see the zip file with post#5)
    http://www.alteraforum.com/forum/showthread.php?t=43992
    If you use "generate" from the Qsys GUI, the logging dialog box most likely has the sequence you need.
    The same thing goes for generating simulation files; check the checkboxes in the GUI, click generate, and look at the log in the dialog that pops up.
    Cheers,
    Dave
    That was a great suggestion Dave.
    I have progressed further, but I am having trouble figuring out the steps to generate the SoC BFM based simulation test benches.
    I can do it in the GUI.
    It is one click on "Generate HDL test benches"
    In the log file I see 2 x calls to ip-generate but there is a call to a TC script tbgen.tcl in between
    Only the output of that script is shown in the report file so I cannot see how it is called.
    There is a comment in the script file
    /tools/altera/14.0/./quartus/sopc_builder/bin/tbgen.tcl
    which suggest it may be called by sop_builder, but I cannot find a command line exec for sop_builder.
    Any suggestions on tracking down the exact calls made by the GUI?
    Thanks again Martin
    ps. a find returns:
    /tools/altera/./14.0/quartus/sopc_builder
    /tools/altera/./14.0/quartus/sopc_builder/bin/sopc_builder.jar
    /tools/altera/./14.0/quartus/sopc_builder/bin/sopc_builder.ptf
    /tools/altera/./14.0/quartus/sopc_builder/model/bin/sopc_builder.pl
    /tools/altera/./14.0/ip/altera/ddr_high_perf/lib/sopc_builder
    /tools/altera/./14.0/ip/altera/ddr_ddr2_sdram/lib/sopc_builder
    /tools/altera/./14.0/ip/altera/ddr3_high_perf/lib/sopc_builder
    /tools/altera/./14.0/ip/altera/pci_compiler/lib/sopc_builder
    /tools/altera/./14.0/ip/altera/pci_compiler/sopc_flow/example/sopc_builder_example_readme.txt
    /tools/altera/./14.0/ip/altera/sopc_builder_ip
    /tools/altera/./14.0/ip/altera/ddr2_high_perf/lib/sopc_builder
    /tools/altera/./14.0/qprogrammer/sopc_builder
    --- Quote Start ---
    --- Quote End ---
    Can you copy-and-paste the contents of the generate GUI and email it to me (to my forum name), or just post it to this thread as a .txt attachment. It'll help to see the complete output.
    I'm not sure that I'll be able to find a solution, but at least I can confirm its confusing, and you could then file a Service Request with Altera :)
    Lets see if we can figure it out first ...
    Cheers,
    Dave
    I uploaded the full report file:
    ghrd_5astfd5k3_generation.rpt.txt.
    I had to append the .txt to upload.
    I need to figure out 2x things.
    How to run sop_builder command line under Linux.
    And what the arguments are to the script.
    Thanks Martin
    --- Quote Start ---
    --- Quote End ---
    Thanks. Based on the fact that ip-generate only runs twice, I guess you only had simulation and testbench options selected (not synthesis). (I don't care that synthesis was not checked, I'm just making an observation).
    --- Quote Start ---
    --- Quote End ---
    There is no sopc_builder any more (the fact that the name exists as part of the tool path is due to Altera not making their filesystem paths consistent with their tool names). I think this is an error in your thinking. There is only ip-generate, or qsys-generate (according to the 14.0 documentation!).
    --- Quote Start ---
    --- Quote End ---
    Its more likely that the script is an argument to ip-generate, than to sopc_builder.
    Ok, I see the message ...
    Info: Running script /net/tcfiler2.scs.agilent.com/vol/v51/rpdhw/tools/altera/14.0/quartus/sopc_builder/bin/tbgen.tcl
    I'll go login on my 14.0 machine (Windows 7) and look at this script. I'll see if I can figure out what command-line tool it is run with, eg., ip-generate or something else.
    Cheers,
    Dave
    --- Quote Start ---
    --- Quote End ---
    The script comments imply that it used to be run by a tool called sopc_builder, but there is no sopc_builder.exe file in that directory any more.
    Looking in the 12.1 directory shows that sopc_builder used to be a perl script that called sopc_builder_classic.pl which is also no longer in the 14.0 installation.
    I tried running qsys-script on the tbgen.tcl file with a qsys_system.qsys file I had, but it failed.
    Its time for you to create a simplified version of your design and file a service request with Altera. Please post the design and results here if you can, so that others can comment, or learn (hopefully from your success).
    Cheers,
    Dave
    Hey Martin,
    Since you are playing with these tools, take a look at de0_nano_sdram.zip in this thread;
    http://www.alteraforum.com/forum/showthread.php?t=45927
    The thing you want to look at is scripts/qsys_system.tcl, i.e., the Qsys system has been converted to a Tcl script, rather than an XML file. This allows the differences in Quartus versions to be absorbed into the Tcl. For example, the SDRAM controller parameters have changed.
    I suspect that your hierarchical qsys system could be converted to several Tcl scripts that might be a little easier to maintain ...
    Cheers,
    Dave
