11 years agoI don't know the answer to the hierarchy question, but I have a suggestion that might work ...
To determine what arguments to pass to ip-generate, I use the GUI and then copy the ip-generate arguments into a script, eg., this BeMicroCV design has an example for the DDR controller (see the zip file with post#5) http://www.alteraforum.com/forum/showthread.php?t=43992 If you use "generate" from the Qsys GUI, the logging dialog box most likely has the sequence you need. The same thing goes for generating simulation files; check the checkboxes in the GUI, click generate, and look at the log in the dialog that pops up. Cheers, Dave
