11 years ago --- Quote Start --- ghrd_5astfd5k3_generation.rpt.txt. --- Quote End --- Thanks. Based on the fact that ip-generate only runs twice, I guess you only had simulation and testbench options selected (not synthesis). (I don't care that synthesis was not checked, I'm just making an observation). --- Quote Start --- How to run sop_builder command line under Linux. --- Quote End --- There is no sopc_builder any more (the fact that the name exists as part of the tool path is due to Altera not making their filesystem paths consistent with their tool names). I think this is an error in your thinking. There is only ip-generate, or qsys-generate (according to the 14.0 documentation!). --- Quote Start --- And what the arguments are to the script. --- Quote End --- Its more likely that the script is an argument to ip-generate, than to sopc_builder. Ok, I see the message ...
Info: Running script /net/tcfiler2.scs.agilent.com/vol/v51/rpdhw/tools/altera/14.0/quartus/sopc_builder/bin/tbgen.tcl
I'll go login on my 14.0 machine (Windows 7) and look at this script. I'll see if I can figure out what command-line tool it is run with, eg., ip-generate or something else. Cheers, Dave
