11 years ago --- Quote Start --- I'll go login on my 14.0 machine (Windows 7) and look at this script. I'll see if I can figure out what command-line tool it is run with, eg., ip-generate or something else. --- Quote End --- The script comments imply that it used to be run by a tool called sopc_builder, but there is no sopc_builder.exe file in that directory any more. Looking in the 12.1 directory shows that sopc_builder used to be a perl script that called sopc_builder_classic.pl which is also no longer in the 14.0 installation. I tried running qsys-script on the tbgen.tcl file with a qsys_system.qsys file I had, but it failed. Its time for you to create a simplified version of your design and file a service request with Altera. Please post the design and results here if you can, so that others can comment, or learn (hopefully from your success). Cheers, Dave
