9 years ago
FIFO Outputs all HiZ in RTL Simulation
Hi All,
I am still a beginner to FPGAs, but I think I'm making good progress. I am able to simulate my own Verilog code in ModelSim-Altera and everything looks correct.
However, when I try to simulate an Altera Megafunction (DCFIFO in this case) all of the outputs are always HiZ no matter what inputs I give. I have done a lot of searching but I haven't come across anything which solved my problem. All of the other threads I found usually conclude with "Add the libraries", but I have done that. The code compiles fine. I'm running the simulation with "vsim work.sync_fifo -L altera_mf"
Output screenshot is attached.
After looking into the generated code it seems like the Megawizard just generates wrappers. How do I get the actual internals to simulate?
I also understand the during synthesis a lot of optimization happens. Outputs which are not depended on by the rest of the design get removed. But if I am simulating the module directly, this should not happen, correct?
