10 years agoFIFO Outputs all HiZ in RTL Simulation
Hi All, I am still a beginner to FPGAs, but I think I'm making good progress. I am able to simulate my own Verilog code in ModelSim-Altera and everything looks correct. However, when I tr...
10 years agoI'll be totally honest with you, I was running commands directly in ModelSim just to experiement. That is probably a dumb thing to do. I wrote a test bench which produces the attached output.
`timescale 1ns / 100ps
module sync_fifo_tb ();
// Inputs to module
reg clk;
reg wrreq;
reg rdreq;
reg data;
reg sclr;
// Outputs from module
wire q;
wire usedw;
wire full;
wire empty;
// Instantiate device
sync_fifo U1(
.clock(clk),
.data(data),
.rdreq(rdreq),
.sclr(sclr),
.wrreq(wrreq),
.empty(empty),
.full(full),
.q(q),
.usedw(usedw)
// Clock setup
always
# 5 clk = ~clk;
// Initial setup
initial
begin
clk = 0;
sclr = 1;
wrreq = 0;
rdreq = 0;
data = 8'b10101010;
# 50 sclr = 0;
# 20 wrreq = 1;
@(posedge clk); // Wait 5 clocks
@(posedge clk);
@(posedge clk);
@(posedge clk);
@(posedge clk);
# 5 wrreq = 0;
end
endmodule
