External Memory Interface IP on Agilex.
Hi, I am new to Quartus Prime Pro. I have instantiated a external memory interface in a Qsys design for an Agilex part. I have also generated the example design and simulated it. Looking through the associated data sheet, I can't find any description of how to use it! It has an avalon interface (AMM) plus a few other descrete signals (Lock, reset request etc). It is the use of the avalon interface which is not documented. I can't beleive it is just a memory mapped interface, ie you provide the DDR4 address on the avalon bus and read/write the data in this fashion, but maybe it is. It is impossible to say from the user guide or data sheet. It looks like I am missing some documentation. Having said that I have sat through hours of videos on the EMIF. I have designed Xilinx emifs before and all the information required to drive them was in the data sheet. So it looks line I am missing something, but I can't see what.
So anyone who knows how to drive the emif, please put me out of my mysery.
- Big_Al
Having looked at the simulation, it appears there are no transaction on the aMM interface from the TG2. It is not clear from the documentation how to stimulate the TG2 to perform any transactions. It does say it should perform 1 transaction after power-up., and that this could be made infinite by chaging a parameter. That did not seem to work either.
Giving up on the simulation, I looked at the interface on Qsys. There appears to be a 576-bit rd/wr bus and a 29-bit address bus. As the DDR4 I chose is 4Gx72, that suggests a single transfer on 576-bits is 8x72, so the 29-address bits would enable me to get to the whole memory. It is not clear, but there is a 7-bit burst count field, so potentially I could send 128x576bits in a single burst (the max allowed by Avalon). I presume the emif interface would wait for all 128 576-bit words to be loaded into it's buffer before it tried to burst them at the DDR.
One thing which is not clear is why there appears to be no byteenables on the emif interface? As I will be writing an Avalon master I can add them (72 of them) and try to connect the interfaces together in Qsys. I suppose it will either throw an error or work.
Again, it strikes me I am missing some important document somewhere which describes how to use this interface.
Answers on a postcard please.
- sstrell
Have you gone through the user guide? There's a lot to setting up an EMIF:
- Big_Al
Yes, I have been through all the documentation and videos. The user guide seems to concentrate mainly on the phy side, which is all very interesting but what I really want to know more about from a user point of view is the Avalon interface. I could try to work it out from my own test bench, but I can't help but think it is probably documented somewhere, which would save me a lot of time.- sstrell
What aspect of Avalon? Avalon in general or like the register map of the EMIF IP? You can learn more about Avalon itself in the spec:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf
- AdzimZM_Altera
Hello Sir,
May I know if you're using Example Design or your custom design?
I can see the signals like below from the Example Design.
- tg_ctrl_amm_0_waitrequest;
- [575:0] tg_ctrl_amm_0_readdata;
- tg_ctrl_amm_0_read;
- [32:0] tg_ctrl_amm_0_address;
- [71:0] tg_ctrl_amm_0_byteenable;
- tg_ctrl_amm_0_readdatavalid;
- tg_ctrl_amm_0_write;
- [575:0] tg_ctrl_amm_0_writedata;
- [6:0] tg_ctrl_amm_0_burstcount;
I think those signals are from the traffic generator that interact with the external memory interface.
Please let me know if you need help on creating the Example Design.
I think that by enabling ECC, your data bit will become 64bit + 8bit ECC.
So there will be a total of 72bit.
Adzim
- Big_Al
Hi Adzim,
As I mentioned above (11-07-2021) I simulated the example design. The interface signal that I showed were from the EMIF IP I generated in Qsys. My error was that I hadn't enabled the Data Mask option. Apparently this is required to get the byte enables.
Interestingly when I enable Data Masks I can't enable DBI to improve SI (they are mutually exclusive). When I try to create the IP it suggests I should use DBI as it is over 1200MHz clock speed. So that seems to suggest is you run a DDR4 RDIMM at 2666 or 3200 you shouldn't access anything less than 576-bit words at a time. So all byte changes would need to be a read-modify-write. That doesn't sound very efficient.
Next, I was planning on using a MTA36ASF4G72PZ – 32GB external RDIMM as simulated on our Intel development board schematics. This is a dual rank device with 4 DQ pins per DQS group. When I select Data Mask, an error pops up saying 'Data Masks are not supported in x4 modes'. So it looks like for this RDIMM, you cannot access anything less than 576-bits (or 512 if ECC is enabled). At least the questions I had about ECC seem to now be resolved. With ECC enabled, the interface drops down to 512-bits wide, so at least that now makes sense.
What is not clear from the documentation still is the timing of writes to the DDR4. I can write up to 128 512-bit words at a time to the Avalon interface. The question is when do they start to be transferred to the physical memory. Is it only when all 128 words have been written or as soon as each word is written. I suppose I will have to simulate it and find out.
Thanks for your help.
- Big_Al
Another question arrises regarding access to the EMIF. I have an HPS with Arm in it which wants to load the DDR4 with test data. I then have some custom IP which reads that data out and sends it to a DAC via JESD, while also collecting data from an ADC and writing it to the EMIF.
1) The EMIF only has a single Avalon port (if you ignore the optional configuration port). I presume these 2 interfaces to the EMIF, one from the HPS and one from the Custom IP will need to go via an Avalon bridge to the EMIF. Is this correct?
2) In Qsys, does this happen automatically when I connect them directly together or do I have to add a bridge to the design?
3) Is it possible that HPS can have byte access to the physical DDR while the Custom IP does not. It sounds like that is not possible?
4) Does the bridge convert between the 512-bit wide data buses from the EMIF to the 32/64 bit interface on the HPS. I presume it must do. Can you point me to documentation which explains this please?
5) If say the HPS has a 64-bit interface, then how does writing to the EMIF work? Does the bridge implement some width conversion logic which collects 8 64-bit words before writing? What happens when fewer that 8 words are written?
- AdzimZM_Altera
Hi Sir,
Thanks for your reply and feedback the issue.
I'm really appreciate it.
I think it's will transferred immediately because the operation is required the location for it to store the data.
You can simulate it to find on how your data are been processed.
Adzim
- Big_Al
Re my last post, I have found the video "Custom Component Development Using Avalon® and Arm* AMBA* AXI Interfaces" which has answered most of this.
- Timothy_W_Intel
updated link: Custom Component using avalon and axi
- nelky
Do you have the sample of how I can read from and write to external SDRAM through Linux driver on Agilex 7?
I need to use the SDRAM as temporary storage and also to use the bridge to access to the peripherals, like UART, I2C, SPI.
I guess there are 2 parts here.
Firstly, we need to setup the connection using Quartus platform Designer. From here, we can generate the avalon-mm addresses.
Secondly, we need to write a Linux driver to access to these avalon-mm addresses in order to read and write.
Am I correct to say that?
But I can't find the sample on this project. Could someone please help direct me to the proper sample?
I guess there is a Cyclone V one. But its architecture isn't the same. I can't use the Cyclone V one on Agilex 7.
Please help.
