JPrig's avatar
JPrig
4 months ago
Power Analyzer for Cyclone 10 GX
I work on a project for Cyclone 10 GX. I would like to estimate current consumption per voltage based on the actual VHDL code and later based on actual simulation results. Power Analyzer inside Quartus does not seem to support Cyclone 10 GX. What tool should I use?
  • OK, you're talking about the PTA for early power estimates, not the Power Analyzer within Quartus (used to be referred to as "Powerplay") that provides a final power analysis of your design after compilation which supports all devices supported by that edition of Quartus.  Neither the PTA nor the older PTC support Cyclone 10 GX.
    For early power estimates for Cyclone 10 GX, you have to use the appropriate early power estimator (EPE) spreadsheet:
    https://www.altera.com/design/resource/power/epe-and-pa
  • sstrell's avatar
    sstrell
    What makes you think it's not supported?
    https://docs.altera.com/r/docs/683174/current
    • JPrig's avatar
      JPrig
      because I get this error message when I attempt to start the Power Analyzer and Cyclone 10 GX is not on the list.
      • KennyT_altera's avatar
        KennyT_altera
        Do you have further queries? If no, we shall close this thread.
  • sstrell's avatar
    sstrell
      KennyT_altera
      Just to add: For initial estimates, use the EPE spreadsheet for Cyclone 10 GX, and once your design is compiled in Quartus, you can use the Power Analyzer for more accurate, design-specific results.
