gabriel65's avatar
gabriel65
1 month ago
Problema Usb_Blaster con Windows 11
Como lograr que Windows 11 reconozca el Drive de mi USB_BLASTER. Podrán enviar la información al correo [email protected], ya intente varias formas y no logro resolver el problema. Muchas gracias por sus atenciones, saludos a todos.
1 Reply
  • FakhrulA_altera's avatar
    FakhrulA_altera
    Hello gabriel65,
    Thank you for your question.
    To provide the correct driver, could you please confirm whether your cable is a USB-Blaster, USB-Blaster II, or USB-Blaster III, as well as the exact Quartus Prime and Windows 11 versions?
    As a first step, install the driver from the drivers folder in the same Quartus installation, using Windows Device Manager and selecting Update driver > Browse my computer for drivers. For USB-Blaster II, the usual location is drivers\usb-blaster-ii; please do not mix drivers from different Quartus versions. You may also refer to the KDB https://community.altera.com/kb/knowledge-base/update-driver-software---usb-blaster-windows-encountered-a-problem-installing-th/345148
    If the issue persists, please provide the cable model, Quartus Prime and Windows 11 version/build, the exact error message, and a screenshot of Device Manager. With this information, we can confirm compatibility and recommend the next steps.
    Best regards.
    Fakhrul
