Big_Al
4 years agoExternal Memory Interface IP on Agilex.
Hi, I am new to Quartus Prime Pro. I have instantiated a external memory interface in a Qsys design for an Agilex part. I have also generated the example design and simulated it. Looking through the ...
sstrell
4 years agoHave you gone through the user guide? There's a lot to setting up an EMIF:
Big_Al
4 years agoYes, I have been through all the documentation and videos. The user guide seems to concentrate mainly on the phy side, which is all very interesting but what I really want to know more about from a user point of view is the Avalon interface. I could try to work it out from my own test bench, but I can't help but think it is probably documented somewhere, which would save me a lot of time.
- sstrell4 years ago
What aspect of Avalon? Avalon in general or like the register map of the EMIF IP? You can learn more about Avalon itself in the spec:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf
- Big_Al4 years ago
I have read the Avalon specs and have used axi before. My specific issue is as I mentioned above on the 5 Nov. The Avalon interface on the emif is 576 bits wide. There are no byte enables and only 29 address bits. So if I want to write to a Specific byte, how can I do this? I would have thought this might be explained somewhere along with other questions like details on when a burst mode starts. Is it after the last bytes of the last 576 byte word is written?- Big_Al4 years ago
Maybe I should be more specific. I have generated an external memory IP module for an Agilex fpga, which interfaces to a 32GB (4Gx72) DIMM. It has the following user Avalon interface (amm):
Avalon Interface:Name Role Width Direction Description amm_ready_0 waitrequest_n 1 Output Wait-request is asserted when controller is busy amm_read_0 read 1 Input Read request signal amm_write_0 write 1 Input Write request signal amm_address_0 address 29 Input Address for the read/write request amm_readdata_0 readdata 576 Output Read data amm_writedata_0 writedata 576 Input Write data amm_burstcount_0 burstcount 7 Input Number of transfers in each read/write burst amm_readdatavalid_0 readdatavalid 1 Output Indicates whether read data is valid So, on the face of it I there is a 29-bit address bus which allows unique access to 0.5G address space. So, I can access the full 32GB memory in increments of 576-bits (= 8x72).There appears to be no byte enables, so it would suggest I can only access data in 576-bit resolution. Either that or if I want to modify a byte, it would require a 576-bit read-modify-write operation. This doesn't sound right!Avalon clearly supports byte-enables, although in this case I would require 72-byte-enables. That doesn't sound right either.So it looks like I am going wrong somewhere?Unfortunately, the documentation doesn't discuss this aspect of the emif very much. There are many other aspects to this interface which are conspicuous by their absence from the documentation, which make me think I am missing a document somewhere. I just need a few simply examples of writing to and reading from the amm.I have watched the 4 videos on the subject, generated and simulated the example code and read the External Memory Interfaces Intel Agilex™ FPGA IP User Guide. I also read the Avalon specs.
